Do you know?? Electrical Issue - JeepForum.com
post #1 of 4 Old 06-01-2012, 07:23 AM Thread Starter
srmkenzie
Vehicle: 2001 Jeep Grand Cherokee Limited V8
We have been battling with our Jeep over the past year. I read a lot about them having electrical issues. This time I want advice instead of wasting money on parts that aren't the problem.
So far we replaced the battery, some fuses, and the starter.
Issue: The Jeep goes from having normal voltage on the gauge to nothing. Interior lights dim and display, where the compass and degrees are, shuts off. Most of the time it starts, but it will putter. When using the A/C or heater the voltage was staying around 14 on the gauge. When it is shut off the gauge drops. Last night going home, the gauge just dropped completely and check engine light came on. The battery had corrosion on the negative post so we tried another battery, but it was still not working right. I have codes P1682 and P1499 coming up. Is it the battery again? Is it a bad alternator? Is it bad battery cables? What else could it be?
Advice and experience is needed and much appreciated.
srmkenzie is offline
post #2 of 4 Old 06-01-2012, 02:31 PM Thread Starter
srmkenzie
Replaced alternator and now everything works fine!
post #3 of 4 Old 05-08-2013, 10:03 PM
nickcospo
I have the same problem but had my alternator checked and it is good idk what to do
nickcospo is offline
post #4 of 4 Old 05-09-2013, 07:08 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Where did you have it checked? Autozone does not always catch the bad ones and I personally don't trust them.
Start with the basics.
How old is the battery and alternator? Check your clamps, are they clean and tight? Check the grounds, are they clean and tight as well? High milage alternators can have low/intermittent output.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
alternator problem , battery , electrical , electrical issue , no power
Electrical issue? PCRIDE Audio, CB & Ham Radios, GPS, & Electrical 5 03-31-2012 02:50 PM
TJ Electrical Issue Rtrotter8 Audio, CB & Ham Radios, GPS, & Electrical 2 12-21-2011 12:11 AM
94 GC electrical issue xslicerx Audio, CB & Ham Radios, GPS, & Electrical 0 04-20-2011 05:56 PM
Please help...electrical issue KATHYSCHMIDT Audio, CB & Ham Radios, GPS, & Electrical 8 07-23-2010 04:46 PM
Odd? Electrical Issue? Johnny5isAlive Audio, CB & Ham Radios, GPS, & Electrical 3 04-17-2007 12:40 PM
