Do I need a larger alternator to run off road lights? - Page 2 - JeepForum.com
post #16 of 22 Old 09-21-2013, 04:15 PM
nutters
We have three lights on a bumper bar and five on a roof bar. Will we need a bigger battery or another alternater? I have a 2013 JK Wrangler Sport with 3.6 L V6 24-Valve VVT engine. I don't know what other info yall might need as I'm asking for my husband. I have a 600 Amp Maintenance free battery. The lights are Rugged Ridge 100w. Any help would be greatly appreciated. (I didn't know if I could post on this one or if I should create a new thread)
nutters is offline
post #17 of 22 Old 09-24-2013, 08:07 PM
JPNinPA
800W at 12V (worst case) will yield a 66.66 A load (56A normal). If you plan on running them all at the same time when the engine running you should upgrade the altinator and the power and ground wires at the battery and altinator.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #18 of 22 Old 09-24-2013, 09:46 PM
Indy
Indy's Avatar
Where are you getting 800w? He's running 260w in lights, with a low output of 14v while running he's burning 18ish amps. Stock alt will handle that additional load easily. But you should be running that load through a relay and not just the switch, which odds are you are doing.
But anyways an over drain is easy to see, everything will gradually dim, the jeep wont just die and leave the lighs running.
I'm the only gay eskimo.
Indy is offline
post #19 of 22 Old 09-24-2013, 09:49 PM
Indy
Indy's Avatar
Ah nevermind. Why in the world does every newbie ressurect decades old threads?
Indy is offline
post #20 of 22 Old 09-25-2013, 07:41 PM
JPNinPA
I don't know? He has eight 100W lights added and worst case a 12v battery.
Also the thread is from Jan 31 2012. Hardly close to decades old.
JPNinPA is offline
post #21 of 22 Old 09-25-2013, 07:45 PM
Bmel17
What does it matter. At least they used the search function. Thread still has relevance to them.
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #22 of 22 Old 09-27-2013, 05:18 PM
Gearhead31
Originally Posted by sjones26573 View Post
if hooked up properly, correct.
+2
Edit:
didn't see second page >_< might help to check that out next time..
Gearhead31 is offline
Ultimate larger off road, bad weather, survival vehicle? Please help me pick. kip42 General Jeep & Off-Road Equipment 18 09-12-2010 09:47 PM
Off Road Lights vs. Driving Lights Viorio General Jeep & Off-Road Equipment 2 08-27-2010 08:15 PM
battery and alternator upgrade for lights? haymaker4life General Jeep & Off-Road Equipment 2 03-24-2009 08:20 PM
do I need a larger alternator? ABerry Stereos, CB & Ham Radios, GPS, & Electrical. 1 02-23-2009 11:55 AM
What lights are NOT for on-road use abnormal Stereos, CB & Ham Radios, GPS, & Electrical. 1 12-29-2005 11:45 AM
