Do I need a larger alternator to run off road lights? - JeepForum.com
post #1 of 22 Old 01-31-2012, 02:48 PM Thread Starter
cdywhitney24
So I just recently got a pair of KC off roading lights and mounted them to my windshield. I hooked them up and they turned off and on perfectly while sitting in the garage. Later that evening I was driving down the road and thought I would try them out. Turned them on and it killed my engine. The lights stayed on but everything else went out. When I pulled over I turned the lights off and the engine fired right back up. The lights work just fine when the engine is not running, but everytime the engine is running the lights will kill it. Does this mean I need a larger alternator? Everything on my YJ is stock.
cdywhitney24 is offline
post #2 of 22 Old 01-31-2012, 03:27 PM
Rudinater
2009 JK Wrangler
Check your wiring, something is not right.
You could have every light know to man installed on there and just turning them on will not kill your engine. They will however drain you battery.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #3 of 22 Old 01-31-2012, 03:31 PM
sjones26573
Yea somethings not right there. I run two pairs of kc 130w daylighters in addition to my headlights. 1 pair of lights definately wont kill the engine. Lights dont affect the engine. They may overload the alternator, blow a fuse, or melt some wire, but not kill the engine. Are you sure thats the issue?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #4 of 22 Old 01-31-2012, 04:30 PM Thread Starter
cdywhitney24
I have no idea what the problem is. I followed the instructions and hooked them up exactly how it told me too. The lights are KC 130 watt each. I was talking with some people and they said that they may be sucking out all the power just to turn them on while I am driving and that I may need a larger alternator. Any other ideas on why I cant get it all to work. I see all these other jeeps with multiple sets of lights and winches and am just curious how they get all that to work because I cant even get one set of lights to work.
post #5 of 22 Old 01-31-2012, 07:25 PM
Jrob05
Could you possibly have a positive and negative connection backwards?
Jrob05 is offline
post #6 of 22 Old 01-31-2012, 07:28 PM
Dickpalmer
If you have them wired through the ignition wire for a hot wire, that could do it. You may have a lighted switch wired wrong and shorting the ignition. Does your engine just cut off immediately? If it does check the above suggestions.
Dickpalmer is offline
post #7 of 22 Old 01-31-2012, 07:29 PM
JPNinPA
I have six 130W lights and an amp. All running at idle with no issues. You likely either have a short on the light side of the circuit. A dieing battery or you have a battery/alternator wire issue.
You are using a relay and fuse in the light circuit, correct??
http://support.kchilites.com/index.p...ch&attach_id=8
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #8 of 22 Old 01-31-2012, 07:34 PM
Dickpalmer
If the engine started right back up after you turned the lights off than your battery still had power. It's not a battery drain issue. Re- check your wiring or have someone look at it.
post #9 of 22 Old 02-01-2012, 12:42 AM Thread Starter
cdywhitney24
I will have to check my wiring again. I have looked it over many times now. I just put in a brand new battery and my alternator tested good when I took it in. By
post #10 of 22 Old 02-01-2012, 12:43 AM Thread Starter
cdywhitney24
By the sound of it it sounds like I did something wrong. Thank you guys for all your help.
post #11 of 22 Old 02-01-2012, 10:14 AM
Xpress
I've got no problems running 55w HID spotlights and 55w Halogen driving lights with my headlights.
I would go back through and double check every single connection you added onto your Jeep. When wiring up lights like this, it's best to create their own power supply (and NOT tie into other power supplies) by hooking directly into the positive terminal on the battery.
All about that unibody life.
Xpress is offline
post #12 of 22 Old 02-08-2012, 02:43 PM Thread Starter
cdywhitney24
I'm not sure what I am doing wrong. I am going to pay a guy I know 40 bucks to have him hook them up right. I just want to make sure though. I should have no problem running these lights with the stock alternator I have and my new battery right?
post #13 of 22 Old 02-08-2012, 02:49 PM
sjones26573
If hooked up properly, correct.
Jeep-Owner.com
post #14 of 22 Old 02-08-2012, 05:07 PM
Xpress
Yes, like I mentioned I am running 4 aftermarket lights off my stock alternator, sometimes 5 (depends if I'm backing up or not).
Xpress is offline
post #15 of 22 Old 02-08-2012, 06:57 PM
Azalin_00
Originally Posted by sjones26573
if hooked up properly, correct.
^^^x2
Baller on a Budget
My Money
My Ears
My Jeep
Azalin_00 is offline
Ultimate larger off road, bad weather, survival vehicle? Please help me pick. kip42 General Jeep & Off-Road Equipment 18 09-12-2010 09:47 PM
Off Road Lights vs. Driving Lights Viorio General Jeep & Off-Road Equipment 2 08-27-2010 08:15 PM
battery and alternator upgrade for lights? haymaker4life General Jeep & Off-Road Equipment 2 03-24-2009 08:20 PM
do I need a larger alternator? ABerry Audio, CB & Ham Radios, GPS, & Electrical 1 02-23-2009 11:55 AM
What lights are NOT for on-road use abnormal Audio, CB & Ham Radios, GPS, & Electrical 1 12-29-2005 11:45 AM
