do I need a larger alternator? - JeepForum.com
post #1 of 2 Old 02-23-2009, 11:12 AM Thread Starter
ABerry
I'm currently running a true 750-1000rms single JL 12" W7 subwoofer powered by a JL 1000/1 amp. I'm about to install a 4x100rms alpine pdx amplifier to power a set of infinity kappa components for the front and kappa 6.5" 2 ways for the rear... would it be strongly recommended to upgrade to a larger alternator? I have the 4.0 WJ, whats the output of the stock alternator?
IRO 3", BFG MT KM2 31's, MX-6's
University of Oregon ALUMNI GO DUCKS!
ABerry is offline
post #2 of 2 Old 02-23-2009, 11:55 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your alternator is fine. That setup doesn't draw that much power for normal listening levels. Only if you had it cranked up enough to provide sound for a stadium or competition event would it draw even close to what it can draw when it's putting out all of its power. The peak amperage comes right out of the battery when needed. Your alternator is likely 117 amps.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
Larger sub in the center console JBXdudeTJ Audio, CB & Ham Radios, GPS, & Electrical 5 02-23-2009 09:03 AM
Using a Larger Oil Filter 4.0 IL dionysius Engines & Drivetrain 22 10-05-2006 12:04 AM
Mounting Larger spare Elmar66 Tires & Wheels 2 05-16-2005 01:08 PM
Odometer with larger tires?? Nymisus Tires & Wheels 7 10-23-2003 07:05 AM
larger engine? jugger Engines & Drivetrain 16 06-25-2002 07:21 AM
