DIY Rock Lights - Page 2 - JeepForum.com
 3Likes
post #16 of 149 Old 07-17-2013, 08:56 PM
Live4Jeeps
Nice work to both of you who built your lights! I got inspired and ordered mine on Monday so whenever they get here from China, I can start haha
Live4Jeeps is offline
post #17 of 149 Old 07-18-2013, 08:48 PM
hcarlgolden
Awesome job man. Good job on the write up too. This will be added to my list for sure at some point.
Blue Jeep Club Member #384
It's a Jeep, If I wanted a Hummer I would have called your sister.
hcarlgolden is offline
post #18 of 149 Old 07-18-2013, 09:04 PM
JJeeper09
Just ordered some today, I'll post up my locations
JJeeper09 is offline
post #19 of 149 Old 07-23-2013, 06:31 PM
cargo33
Always wantd to do this. Excelent job
cargo33 is offline
post #20 of 149 Old 08-06-2013, 07:17 PM
appfire
Great idea and write-up. My chinese lights came in today and just finished installing them. They are perfect for rock lights.
Chris
All politicans are crooks. They should have to work and pay for everything like we do.
appfire is offline
post #21 of 149 Old 08-06-2013, 07:23 PM Thread Starter
686keydragon
Chris
Excellent! Post up some pics of where you put them if you have time.
2002 TJ, 2.5L, 4" lift, 33" dunlop mud rovers, xrc8 winch, aussie locked d30, a-z fabrication ww2ww sliders, mounted mv-50 compressor, SirGcal sub box
686keydragon is offline
post #22 of 149 Old 08-06-2013, 07:49 PM
JJeeper09
Here is mine
post #23 of 149 Old 08-06-2013, 08:24 PM Thread Starter
686keydragon
Originally Posted by JJeeper09
Here is mine
Looks good!
post #24 of 149 Old 09-03-2013, 07:39 PM Thread Starter
686keydragon
post #25 of 149 Old 09-12-2013, 09:53 PM
graydragon2
How durable are the lights as far as waterproofing and normal offroad beatings.
graydragon2 is offline
post #26 of 149 Old 09-12-2013, 10:18 PM Thread Starter
686keydragon
I have taken them offroad nearly every weekend since installing them, mostly rock crawling but they've been through several water crossings and rain storms and they are still working like they did when they were just installed. They seem pretty durable at this point.
post #27 of 149 Old 10-02-2013, 02:57 PM
jacob1189
I used the same lights!
Consider this: I took the ground wire from each of the pods and bent it back and just used the mounting screw to ground the pod since all but 2 of the locations were on metal; I mounted 1 pod on each side in the plastic behind the rear wheel, I had to run a ground wire to those instead of using the mounting screw. This method would also allow you to troubleshoot a wiring problem fairly easily.
And this: I wired them so that they turn on when I go in reverse, and also when I open my doors, which always makes me smile
Mounting Locals: I don't have any pictures, but I have 3 on the front, 2 in each of the front wheel wells, 3 on each side between the wheels aiming down/out, 1 on each side between the wheels aiming inward at the front of the skid plate, 1 in each rear wheel well, and 3 in the rear.
jacob1189 is offline
post #28 of 149 Old 10-02-2013, 03:02 PM
Live4Jeeps
Genius! Can you inform us on the wiring locations to do the same?? I have mine mounted in but not powered yet so if I can do all that before, it would be much easier
post #29 of 149 Old 10-02-2013, 05:17 PM
jacob1189
I took the reverse light power from the rear of the jeep (spliced into the reverse lights) but make sure you use a diode to keep the power from the lights hitting the actual reverse lights (which would turn on the reverse lights anytime you turned on the rock lights/opened the door etc.)
Then I tapped into the dome lights by the driver's feet (I can't remember which wires the power/ground are exactly, but I tapped in near the harness) again, using a diode so that your dome lights don't pop on in reverse/when the rock lights are switched on.
I like being seen better when pulling out of a dark parking spot; but really, the dome light tap is the better of the two mods, it's cool looking and it helps everyone see the running boards!
post #30 of 149 Old 10-02-2013, 11:16 PM
Live4Jeeps
I'd hate to ask this of you, but could you ellaborate on the use of the diode? I'm good with wiring and basic electronics but I've never used diodes before. Any help is appreciated as to where and how they're wired in
