disconnecting sub - JeepForum.com
post #1 of 5 Old 09-06-2010, 04:17 PM Thread Starter
wildwrangler48
disconnecting sub
i need some help disconnecting the stock subwoofer in the console on an 03 wrangler sahara. thanks
wildwrangler48 is offline
post #2 of 5 Old 09-06-2010, 04:23 PM
Jeepster2k3
there are 4 total screws holding the console down, one to the right of the shifter one in the middle to cup holders and 2 under the rear cup holders. Once those are out the whole thing will lift up and the sub is connected via a large connector under the storage part, just disconnect that.
Jeepster2k3 is offline
post #3 of 5 Old 09-07-2010, 06:48 PM Thread Starter
wildwrangler48
thanks for the help
post #4 of 5 Old 09-07-2010, 06:51 PM
Fropleyqk
Fropleyqk's Avatar
There was a write up I just read detailing the replacement of the stock sub in the Electrical forum. Try digging around there too. Theres a lot of good info in there...
edit: nevermind. Im already here... not sure how that happened....
Fropleyqk is offline
post #5 of 5 Old 09-07-2010, 07:05 PM
Demp
This. The cup holders can be pulled straight out in front, they have small rubber tabs holding em in.
To get the sub free there are some screws holding it to the console facing the driver (where the grill slots are, 3 screws). The brass brackets are only needed for the sub assembly itself and can be safely removed.
Also remove fuse 3 from your fusebox in the glovebox. That is what powers the amp for the sub and prevents any water making an accidental contact and blowing a speaker or head unit (or just that fuse).
Demp is offline
Driveshaft disconnecting JeepRubi04 TJ Wrangler Technical Forum 19 06-18-2009 10:01 AM
Disconnecting Swaybar bakwoodj2 YJ Wrangler Technical Forum 22 12-21-2007 09:26 PM
Disconnecting necessary? Bergheimer TJ Wrangler Technical Forum 2 09-20-2007 10:12 AM
Help disconnecting trackbar Broklee TJ Wrangler Technical Forum 12 08-24-2006 06:36 PM
Disconnecting ABS 93YJjeep YJ Wrangler Technical Forum 2 03-22-2005 10:04 AM
