Deep Cycle Battery - JeepForum.com
 2Likes
  • 2 Post By cranbiz
post #1 of 11 Old 02-16-2017, 08:36 AM Thread Starter
OldJackTheJeep
Deep Cycle Battery
Any recommendation for "best" deep cycle for use as power foe all the other stuff when parked on not running the engine. Not really wanting to do a true dual battery set up.
OldJackTheJeep is offline
post #2 of 11 Old 02-16-2017, 10:39 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You don't want a deep cycle battery, they're not a good choice for a Jeep... they don't have as much deep capacity or cranking amps. Their only benefit is they can get drawn down so the battery is dead without as much damage. Just get a good AGM (absorbed glass mat) battery with a good high 750-850 CCA rating and you'll be good to go. AGM batteries (which are not gel cells) are far more rugged than conventional wet acid batteries and better able to withstand the shocks and jolts of offroading. Leave the deep cycle batteries for boats, trailers, & golf carts.
Jerry Bransford is online now
post #3 of 11 Old 02-16-2017, 01:40 PM Thread Starter
OldJackTheJeep
Hmmm, ok this will be serving as power for a Kenwood and a Alinco ALA field shack. Any particular brand?
post #4 of 11 Old 02-16-2017, 04:02 PM
222Doc
222Doc's Avatar
when i wanted extended power to a camper that was used in remote areas I use two 6v deep cells in series.
222Doc is offline
post #5 of 11 Old 02-16-2017, 04:03 PM
Jerry Bransford
Administrator
It doesn't really matter, most AGM batteries are well made. If the sky's the limit it'd be tough to beat the Odyssey PC1500. Bosch Platinum is a fine AGM battery too.
The one battery brand I would definitely avoid now, after having installed three of them into my TJs that all failed prematurely is Optima. Optima used to make superb batteries until Johnson Controls bought them and moved all of their manufacturing down to Mexico. Their reputation went into the toilet after that... of course all that is just my personal opinion.
post #6 of 11 Old 02-16-2017, 05:20 PM
wilson1010
When there is to be a lot of off alternator drain, I think there is no substitute for a second battery which can and should be a deep cycle. Any car battery has surprisingly little continuous power, especially converted to 110v ac which is what I suppose your field station set up consumes.
Tell us what the actual power consumption is and thaat will lead to a better answer.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #7 of 11 Old 02-17-2017, 09:20 AM Thread Starter
OldJackTheJeep
12v is what I'll be running. full power draw on both combined is 45A, but won't be using both at same time and not full power unless necessary. 50% duty cycle at best for short periods. Second battery is the point, just want it as a stand alone not tied to primary Jeep starting set-up.
post #8 of 11 Old 02-19-2017, 02:09 AM
wilson1010
Theoretical lead acid ah are notoriously just that, theoretical.
Assume performance is actually 60% ah of rating. 50% duty cycle (multiply by two), 45A load, 1000 ah rating, that's about 24 hours to DOA.
post #9 of 11 Old 02-19-2017, 04:58 AM
jay-h
Deep cycle batteries are designed for different loading. In a nutshell:
Deep cycles are for low to very moderate loads over extended periods of time and tolerate runing down very low. Conventional batteries are designed for heavy loads (cranking) for short periods of time and do not like running down low. The heavy load of cranking will deteriorate deep cycle batteries
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 11 Old 02-20-2017, 01:09 PM Thread Starter
OldJackTheJeep
Thanks for the information folks!!
post #11 of 11 Old 02-21-2017, 12:03 PM
cranbiz
If on a budget, consider the Advance Auto Platinum AGM battery. They are made by Enersys (who also make the Odyssey battery).
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
