Custom Switch - JeepForum.com
post #1 of 10 Old 02-10-2013, 04:02 PM Thread Starter
RBX_pawtracks
Custom Switch
Is it possible to have a rocker switch that when turned on every light on a jeep will turn off, including the dashboard?
Sent from my Samsung Galaxy S II Skyrocket using the JeepForum app.
RBX_pawtracks is offline
post #2 of 10 Old 02-10-2013, 04:07 PM
sjones26573
Yes, if you use it to power a bank of NC relays hooked in to all of the lights.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 10 Old 02-10-2013, 04:10 PM
JimWilliamson
Yes.
To have one master switch to turn off all lights - you might not enjoy the amount if re-wiring you'd have to undertake.
The shorter alternative would be to...
1) Hit the already installed switch to turn off your headlights & parking/running lights.
2) Hit the already installed switch(es) to turn off your radio / electronics.
3) Install one switch to disable the brake lights so you could press the brake pedal but not get the lights [or just don't use the brake pedal] (legality issues might be there for on-road use).
4) Edit: door open dome lights, if you have them (you don't have your vehicle listed in your profile) might be an additional concern - if you wish to open your doors w/o light(s).
5) Edit2: Dang - didn't think (again, what vehicle do you have) about certain dash lights - Check Engine, Oil Pressure, Low Fuel, Upshift indicator...
Again, how much wiring are you looking to tend to get what you want?
JimWilliamson is offline
post #4 of 10 Old 02-10-2013, 04:16 PM Thread Starter
RBX_pawtracks
I wasn't planning on doing this I just wanted to know if it is possible. so I will consider doing this. thank you.
post #5 of 10 Old 02-11-2013, 06:57 AM
Demp
This confuses me greatly.
As the others said it is possible but would require very significant work with relays.
Demp is offline
post #6 of 10 Old 02-12-2013, 04:03 PM
bgredjeep
1987 YJ Wrangler
The only lights you need a kill switch for specifically is the brake lights. I'm just saying
bgredjeep is offline
post #7 of 10 Old 02-12-2013, 09:18 PM Thread Starter
RBX_pawtracks
I was originally just asking because I was wondering if I was even possible even though I wasn't planning on do it. Now I am going to it.
post #8 of 10 Old 02-12-2013, 10:01 PM
sjones26573
It will take forever and cost well over a hundred bucks.
Jeep-Owner.com
post #9 of 10 Old 02-13-2013, 02:33 PM
ShinyWJ
Not sure if trolling?
ShinyWJ is offline
post #10 of 10 Old 02-13-2013, 07:25 PM
2jhanna
Down South we would label this switch "hiding from the revenuers" switch.
For you Northerners, running moonshine late at night and needing to go black quick.
To the OP, pretty much any thing can be done given enough time and money, heck, there are some that believe we even put people on the moon.
jhanna
denton county, tx
2jhanna is offline
