Cruise control fuse? - JeepForum.com
post #1 of 2 Old 07-01-2007, 03:59 PM Thread Starter
Rubi22
Rubi22's Avatar
Which fuse, if any, control the cruise control? I located the horn in the engine-bay fusebox, but i don't see any specifically for CC. i'm asking because my cruise and horn recently stopped working (by the push of the steering wheel--it still works when i hit the sentry key), and i'm troubleshooting a fix. first will be the fuses, then the clock spring (??)...
any advice?
Rubi22 is offline
post #2 of 2 Old 07-01-2007, 06:45 PM
Rocky529
Rocky529's Avatar
There is no fuse for the cruise control.
Your issue lies within your clockspring in your steering column.
If it recently got wet, let it dry out and it should work. Otherwise, you are going to have to replace it. Around $100 at the dealership.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
Aftermarket Cruise Control Knocky Audio, CB & Ham Radios, GPS, & Electrical 2 07-08-2009 07:18 PM
cruise control unit not working hillbz Engines & Drivetrain 0 10-14-2007 08:51 PM
Which relay/fuse for Cruise? chrisvr6 Audio, CB & Ham Radios, GPS, & Electrical 0 03-15-2005 10:02 AM
cruise control ANDY31259 Audio, CB & Ham Radios, GPS, & Electrical 3 01-31-2005 06:01 AM
cruise control not working electriczipper Audio, CB & Ham Radios, GPS, & Electrical 0 07-15-2004 09:19 PM
