Are crossovers worth it? - JeepForum.com
post #1 of 22 Old 05-07-2014, 09:27 PM Thread Starter
CoopDogg
I like the idea of having crossovers hooked up to the speakers, but I'm unsure if they are really worth it? Has anyone put them in?
CoopDogg is offline
post #2 of 22 Old 05-08-2014, 08:38 AM
lemiller
Are you running an after market audio system? If not, do you have the infinity system with the stock amplifier under the rear seat?
lemiller is offline
post #3 of 22 Old 05-08-2014, 09:28 AM Thread Starter
CoopDogg
I do have the infinity with stock Amp but I'm replacing the system all at the same time
CoopDogg is offline
post #4 of 22 Old 05-08-2014, 09:31 AM
JCJeep97
Typically, amps have crossovers built in. Amp it rather than crossover IMO.
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #5 of 22 Old 05-08-2014, 09:41 AM Thread Starter
CoopDogg
Sounds like the cheaper route too
CoopDogg is offline
post #6 of 22 Old 05-08-2014, 09:44 AM
lemiller
well if you plan on running tweeters up front, you will certaintly need crossovers to filter out frequencies. If you wont be running tweeters then you probably wont need them and can use the amps built in HPF and LPF (assuming it has them). What head unit, speakers, amp are you planning on running? you going to add a subwoofer as well?
lemiller is offline
post #7 of 22 Old 05-08-2014, 09:52 AM Thread Starter
CoopDogg
Still deciding on if I want to suck it up and go double din out not, I'm thinking either Rockford fosgate or alpine for speakers and then a kicker cvr sub maybe an L7
CoopDogg is offline
post #8 of 22 Old 05-08-2014, 09:53 AM Thread Starter
CoopDogg
And I'll definitely be running a 4 channel amp for the speakers and then a monoblock for the sub. I want to throw in some 3.5in.tweeters where the stock ones are
CoopDogg is offline
post #9 of 22 Old 05-08-2014, 11:00 AM
JCJeep97
I personally don't find tweeters necessary. See what you think with new speakers and a 4 channel first to save some cash. I highly recommend Alpine amps, they put out TONS of clean power for comparatively low costs.
I'm running an Alpine 4 channel 500W RMS to my front and sound bar 5.25's, and a 500W RMS Alpine monoblock to my type R sub and I couldn't be happier.
JCJeep97 is offline
post #10 of 22 Old 05-08-2014, 11:11 AM Thread Starter
CoopDogg
I'll check them out forsure. Any opinion on Rockford fosgate speakers?
CoopDogg is offline
post #11 of 22 Old 05-08-2014, 11:49 AM
lemiller
Duuble din head units are nice but in my opinion they arent really worth the money (to me they are more for show) anywho...fosgate speakers are a quality speaker. The best way to buy speakers though is to go down to a local electronics store (best buy or similar) and listen to a bunch of differnt brands/models of speakers (definitly look at the Polk Audio MM series). Everyones ear is different, so what sounds good to others may not sound the best to you. For your amplifier try to stick with Class D amps, they will run more efficient and cooler (Alpine is a very good brand). If you want tweeters then buy a component set (these will come with tweeters, door speakers, and crossovers).
My set up includes, pioneer head unit, Focal components w/1" tweeters and 6.5" door speakers (had to modify the door to fit) up front, 6x9 Polk Audio MM691 in the rear (again had to modify the door). These are powered by a Polk Audio PA660.4 amplifier. Also have a 12" Rockford Fosgate Punch HX2 subwoofer powered by an Xtant 121M amplifier. To me this sounds great.
lemiller is offline
post #12 of 22 Old 05-08-2014, 12:02 PM Thread Starter
CoopDogg
Where'd you get your adapter plate at for the front doors. I've seen a couple of them with the tweeter hole.
CoopDogg is offline
post #13 of 22 Old 05-08-2014, 12:11 PM
lemiller
oh sorry for the confusion, I have the tweeters in the same location as stock. What I did was cut the tweeter speaker out of the mounting "cage" and then mounted my new tweeter into it. There for it will bolt up to the exact stock location.
I had to use an adapter plate to fit the 6.5" round speakers into the front doors (believe it has an opening for a 6x8 or 6x9). For this, I went to Walmart and bought a cutting board made out of hard plastic. Then made my own adapter plates. This is much stiffer (so reduces flexing) then what you will buy online.
If I have time tonight, I can try to take some pics of my set-up for you.
lemiller is offline
post #14 of 22 Old 05-08-2014, 12:21 PM Thread Starter
CoopDogg
That would be great if you could get some pictures tonight, Thanks!
CoopDogg is offline
post #15 of 22 Old 05-08-2014, 12:29 PM Thread Starter
CoopDogg
So if I'm installing an amp for the sub and an amp for the speakers, do I need a 6 channel Head unit?
CoopDogg is offline
