Compact Amps: Clarion XC1410 vs Alpine KTP-445U - JeepForum.com
post #1 of 16 Old 05-02-2014, 08:02 AM Thread Starter
ciphershort
2009 JK Wrangler
Has anyone recently installed either one of these units? I'm looking for a compact amp that will help out the very poor sound in my JK. I'll most likely be pairing this up with new speakers all around and a head unit. I like the compact amps due to their size and I should be able to stuff them in the dash somewhere. The Clarion seems to be better spec wise but any insight on either would be much appreciated.
Here's a link for spec comparison:
http://www.crutchfield.com/S-IsNQr9W...ower-Pack.html
Clarion XC1410:
Alpine KTP-445U Power Pack:
Thanks!
ciphershort is offline
post #2 of 16 Old 05-02-2014, 01:52 PM Thread Starter
ciphershort
2009 JK Wrangler
Anybody?
post #3 of 16 Old 05-02-2014, 04:07 PM
Jrob05
I have the alpine paired with an alpine HU. It works well. I branched a power feed to the unit off the sub and inverter mounted under the steering column.
Are you looking to boost the factory system or putting a system together?
Jrob05 is offline
post #4 of 16 Old 05-02-2014, 04:36 PM Thread Starter
ciphershort
2009 JK Wrangler
Well be it that my current stock head unit likes to eat CDs (won't eject them all the time) and my passenger front speaker is shot, I'm probably looking at replacing everything. The Clarion seems to give out more power so I was kind of leaning that way but wanted to get some feedback. Both units have great reviews.
post #5 of 16 Old 05-02-2014, 04:52 PM
Jrob05
Being you are replacing everything over time. Base your power choice on which head unit you settle on. Plug and play is kinda nice. I can clearly hear my alpine system with dedicated amp for the 6.5 sub in the center console with the top off at 65+. Pick your HU first is your using one of these compact amps.
Jrob05 is offline
post #6 of 16 Old 05-02-2014, 04:55 PM
nnovickzj
alpine better company in my opinion
97 zj 5.2 40,000mi
locked front and rear, 242, 3.5 iro lift, 32x11.5 kenda klever, 28 laredos for the road
4x 130 watt 6" spots on the roof rack, h3 leds in stock fogs, 2 40w leds on the grill
nnovickzj is offline
post #7 of 16 Old 05-03-2014, 10:02 AM Thread Starter
ciphershort
2009 JK Wrangler
Thanks for the advice. I'm thinking I probably won't be putting in a sub. I'm looking for a good inexpensive HU to start with. Any suggestions on where to start? I've heard good things about Pioneer and Kenwood. I'm also thinking ill do new tweeter and mid range speakers up front and speakers with built in tweeters for the sound bar. That sound like a good direction to start with?
post #8 of 16 Old 05-03-2014, 08:25 PM
06blacklj
I have the clarion installed it's solid but I'm already looking to upgrade it had it for a month it does not dissipate heat well and has over heated multiple times sitting behind the dash of my 06 lj but sq is very good and plenty of power for my2 components up front 5.25 in speaker pods if i can find an adequate spot for ventilation I'll end up keeping because it can make your ears bleed
06blacklj is offline
post #9 of 16 Old 05-03-2014, 08:26 PM
06blacklj
Also wire them with at least 8 guage
post #10 of 16 Old 05-04-2014, 09:45 AM Thread Starter
ciphershort
2009 JK Wrangler
Ok so here's what I'm thinking for my setup. Let me know if I should change anything.
Clarion XC1410 Amp
Polk Audio DB6501 Components Speakers in the front dash
Polk Audio DB651 Coaxial Speakers in the sound bar
Can anyone recommend a good head unit to complete this?
post #11 of 16 Old 05-13-2014, 12:43 PM
gily25
If you're doing a head unit too, I would do the Alpine powerpack and an alpine headunit. I put an Alpine in my 05 back in 2007 and it's still running strong.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #12 of 16 Old 05-13-2014, 01:29 PM
AntiPrius
Get a load of this little amp. They also make a mono version for subwoofers. The 4 channel can be ran 3 channel for subwoofers if needed.
I've done a little research on these, and they seem to be pretty decent, and quite powerful for its size.
http://www.sonicelectronix.com/item_...NVX-MVPA4.html
If you don't really need a CD player because you use an ipod or andriod phone or whatever, look into the new media players that forgo a cd drive all together. I just bought a Pioneer model and use a 128gb USB thumb drive that holds every single song I own. The Pioneer is a nice unit and dirt cheap.
http://www.pioneerelectronics.com/PU...ers/MVH-X560BT
AntiPrius is offline
post #13 of 16 Old 05-14-2014, 11:13 AM
BCrawford64
I actually have the Rockford Fosgate PBR300X4 and it's awesome. VERY small. And well worth the money.
BCrawford64 is offline
post #14 of 16 Old 05-16-2014, 06:10 PM
bbusch
I have installed several 445A units (straight plug and play for the Alpine Head Units) and they have all performed flawlessly. I really like the simplicity and for most listeners plenty of power even with the top down at interstate speeds. I have no experience with the Clarion but given the info posted above about having it overheat I would probably steer clear, the extra 5 watts of power is probably not noticeable (although at 2 ohm 75 watts looks nice but may cause it to overheat). Which ever one you do run I highly recommend running a thicker gauge power and ground wire (not the stock wires) straight from the battery or a power block (make sure you properly fuse, 15 amp should be suffice).
03 Black Rubicon
My Rig
bbusch is offline
post #15 of 16 Old 05-18-2014, 07:06 PM
gregstudeny
2006 WK
This is what I have and it fits behind my stock and tuffy glove box.
gregstudeny is offline
