Coaxial cable - JeepForum.com
post #1 of 5 Old 12-05-2011, 11:51 PM Thread Starter
LWB1217
Coaxial cable
so i just purchased the uniden 520xl and a 4ft firstik 2. im thinking about the teraflex driver side mount. just a little confused about which coaxial cable i should get, how does the firestick connect to the mount, am i missing some small connector piece here?
should i get the coaxial with two pl259 connectors or should i get a coaxial with one pl259 and on the other end terminals?
thanks for the help.
LWB1217 is offline
post #2 of 5 Old 12-05-2011, 11:53 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
RG-58 is what you want. At the biggest I'd use, RG-8x works but is more expensive and not as flexible or easy to run as RG-58 is. I would run RG-58 which is the most popular and perfectly suitable for a CB with that distance between the CB and antenna. RG-59 looks like RG-58 but RG-59 is not the right stuff... make sure it says RG-58.
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 5 Old 12-05-2011, 11:57 PM
andy02
You want the coaxial with two PL259 connectors. To see how to connect the firestick to the mount, look here:
http://www.stu-offroad.com/cb/tfmount/tfmount-1.htm
I agree with Jerry on the type of coaxial to use.
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #4 of 5 Old 12-06-2011, 09:15 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You will need the Teraflex bracket, an antenna mounting stud, coax antenna cable that matches your antenna stud, and the antenna. The two most common antenna studs use either bare wires or a pl-259 screw on cable end.
www.firestik.com has FAQ and TECH sections that explain how to choose your antenna components, how to install them, how to tune the antenna and how to troubleshoot any problems. The info applies to all brands of CB antennas.
CJ7-Tim is offline
post #5 of 5 Old 12-06-2011, 04:23 PM
JPNinPA
Though not a huge issue I'd use the RG-8X despite the added cost.
What ever you pick make sure it is not a solid center conductor. They do not wear well. The center conductor does not like being bent or flexed.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
How my cb cable do I need? toyota4x405 JK Wrangler Technical Forum 25 01-25-2010 01:48 PM
Installing CB Antenna Ball Mount, Coaxial Cable Cutting Delta347 YJ Wrangler Technical Forum 2 11-19-2008 04:51 AM
what is this cable? BoHeck TJ Wrangler Technical Forum 2 05-26-2007 01:39 PM
Name that cable! thejafe TJ Wrangler Technical Forum 36 05-26-2007 01:03 PM
cable 4x4 acmeotally YJ Wrangler Technical Forum 10 05-25-2006 11:40 AM
