Quantcast CJ-7 Factory Tachometer, works but not correctly - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > CJ-7 Factory Tachometer, works but not correctly
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 06-29-2008, 09:17 PM   #1
ET48
I have the original tachometer in my jeep and it reads rpm but about 1,000rpms too high. When I start the jeep the tach stays at zero until I tap on the glass. The tach also moves very erratic. Up and down and not steady with the engine rpms.
I have checked the ground and the wires to the tach and they look fine. There are four wires that go to the back.
Black-ground. Orange-power for backlight. Red-Ignition? Red with white stripe-Coil or computer?
When the key is on I have full power at both red wires, and the same when started. If I unplug the red wires or just one of them the engine shuts off. Can someone please give me some suggestions?
ET48 is offline   Reply With Quote
Old 07-01-2008, 07:54 AM   #2
SirGCal
SirGCal's Avatar
Engine dies from unplugging the TAC? That's not right... But I'd have to see it to know where to look. Sounds like something is going THROUGH the tach which shouldn't be happening. It should just be getting a pulse signal through the coil or wherever.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 07-01-2008, 09:23 PM   #3
ET48
Someone else said the factory tachs were wired in series with the ignition system. The tach measures the volts going through the ignition and not from the coil. All cj jeeps were like this I guess from the factory. All newer tachs and aftermarket tachs plug into the coil. I ordered a new tach so I will see how that goes. Thanks.
Glock Forum
