Cherokee Electrical Problems - JeepForum.com
post #1 of 6 Old 07-06-2011, 04:19 PM Thread Starter
the_red_ranger
Hello all, my Jeep is a 2001 XJ Cherokee Sport 4.0 Liter 6-cylinder that has roughly 130,000 miles on the car and 90,000 on the engine (the original engine 'blew up'). The problems I'm having with it are as follows:
1.) I currently only have sound coming out of my two rear speakers, my door ones don't work at all.
2.) Sometimes the electric windows won't roll down on the passenger and rear doors, but they will roll down when controlled on the driver's door.
3.) I have a keychain remote that will lock/unlock and start/shut off the engine, but the trunk open doesn't work.
4.) The air conditioning works but it's more like a cool breeze than A/C.
Thank you in advance for any help!
the_red_ranger is offline
post #2 of 6 Old 07-06-2011, 05:07 PM
SuperRliBerty
2008 KK Liberty
1.) I currently only have sound coming out of my two rear speakers, my door ones don't work at all.rs
Try the fader to the front speakers only,....still no sound? possible blown output of the radio's amplify. Upgrade radio.
check the Window motor fuse and relay to the control module.
possibel failing truck release solenoid module
Check the R134 fluid level by refilling the compressor. Possible failing compressor, heat exchanger or leaky hoses
Good luck
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #3 of 6 Old 07-06-2011, 05:43 PM
alexherb
1. Cherokees are notorious for wires going bad in the door jamb boot.
2. see 1
3. Did it ever open the trunk? Do cherokees have an electirc trunk release (thought it was manual)?
4. refill it, if that works then goes away youve got a leak.
alexherb is offline
post #4 of 6 Old 07-06-2011, 05:54 PM Thread Starter
the_red_ranger
Thanks a lot!
thetotallyawesomeflyingLiberty- I have already tried that by installing a nice JVC cd stereo.
Alex- How do I get the boot off? And I'm not sure, I've been told the keychain remote is aftermarket.
post #5 of 6 Old 07-08-2011, 03:00 PM
alexherb
im %99.9999 sure a 2001 xj never came with a factory remote starter so that would have to be after market.
bout %89 sure cherokees dont have a factory trunk pop sylonoid so that would also have to be aftermarket.
as far as the boot you should be able to just pull the rubber away from the door or the body or both. Dont know if youll be able to see breaks in the wiring that way though. may have to pull door completely to get a good look at it.
alexherb is offline
post #6 of 6 Old 07-09-2011, 03:10 PM
habeba86
1997 XJ Cherokee
Ive never seen an xj with a factory r/s either, but on my build sheet it said remote start delete as a spec, thought it was weird.
habeba86 is offline
1998 Jeep Cherokee Electrical Problems? Tonymac Audio, CB & Ham Radios, GPS, & Electrical 3 02-03-2014 05:21 PM
electrical problems in 2006 grand jeep cherokee aejames Audio, CB & Ham Radios, GPS, & Electrical 4 09-08-2011 08:25 AM
Electrical Problems with Gage Cluster (Grand Cherokee) Watters Audio, CB & Ham Radios, GPS, & Electrical 2 04-26-2011 09:43 PM
97 jeep grand cherokee electrical problems Dean918 Audio, CB & Ham Radios, GPS, & Electrical 1 01-14-2010 08:39 PM
Electrical Problems SGT Superman Audio, CB & Ham Radios, GPS, & Electrical 1 11-01-2009 08:10 AM
