Charging issue/Question - JeepForum.com
post #1 of 3 Old 10-17-2013, 01:42 AM Thread Starter
tj1072
Hello all.
I have a 2002 Jeep Grand Cherokee Laredo. 6 Cyl/4.0. I am having a strange charging problem that I hope some one can help me with. It has a new alternator already, and the battery tested ok.
Here's what it's doing. Upon startup, the voltage gauge is fairly stable, it fluctuates slightly. As the vehicle warms up, it gets worse, and will vary between a little above 14 on the gauge, to almost down to 9 on the gauge, It does this continuoulsy back and forth, almost as if it's "Hunting". I'm questioning the PCM I guess, as well as the Battery Temp Sensor.
Also, sometimes at idle, the voltage will fall real quick, and the engine changes in sound, almost as if there was a sudden load put on the alternator. When this happens, I get a good amount of engine noise through a subwoofer I have in the vehicle.
Sorry for a long post, just trying to remember all the info I can for you. Thanks in advance.
tj1072 is offline
post #2 of 3 Old 10-17-2013, 09:47 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It sounds like you might have an intermittent systems ground.
I'd look around under the hood for grounding points to disassemble and clean.
***Chris***
chris87xj is offline
post #3 of 3 Old 10-17-2013, 11:18 AM Thread Starter
tj1072
I cleaned up grounds from the battery and such. When it does fluctuate, it's steady. It's not like 3 seconds in between, then 10, then 5. It's slowly like back and forth. I almost question the regulator.
tj1072 is offline
