Changed relay, fuse, and resistor - NO FAN - JeepForum.com
post #1 of 5 Old 06-19-2009, 08:20 AM Thread Starter
tutelo161
My fan on 2002 Liberty stopped working instantly - no burning smell or switch failure. I changed fuse, relay under hood, and resistor behind glove box.
Still dont have a fan 1,2,3,4 do not work - ANY IDEAS ????
tutelo161 is offline
post #2 of 5 Old 06-19-2009, 09:00 AM
SirGCal
RIP
SirGCal's Avatar
Are you talking about the AC/Heat fan? You might have a very common problem with your AC/Heat switch... See examples here:
http://www.sirgcal.com/jeep/pics.html?section=ac_repair
I'd get a DMM and start checking those wires to see where power stops flowing.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 5 Old 06-19-2009, 10:15 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you changed the resistor pack and relay but the fan still doesn't work on any speed, it's either the fan motor itself, the fan switch, or the cable harness. I lost all but my fan's high speed years ago and it was a combination of a burned wiring harness and blown resistor pack.
Jerry Bransford is online now
post #4 of 5 Old 06-21-2009, 08:22 AM Thread Starter
tutelo161
fan works now
I discovered if you unhhook the battery for 30 minutes after changing resistor packs and relays - the computer will reset and the blower fan will work - I had done this when changing out parts to prevent airbag deploy but I was only unhooked for about 5 minutes.
post #5 of 5 Old 06-21-2009, 08:52 AM
SirGCal
RIP
SirGCal's Avatar
That would only be a possibility if it was like a climate controlled GC unit. The TJs, etc. have no computer controlling system for the fan what so ever. If that was the case, it was coincidence, nothing more. A climate controlled system might have some computer interface but I do not have the FSMs for any grands.. So I can't say for sure.
SirGCal is offline
Fuse block & Relay box write-up rustywrangler Audio, CB & Ham Radios, GPS, & Electrical 29 06-04-2010 09:26 PM
aux fuse block relay? lostissues Audio, CB & Ham Radios, GPS, & Electrical 16 04-04-2007 09:13 PM
Fuse panel and relay pack source Davejb Audio, CB & Ham Radios, GPS, & Electrical 0 02-21-2007 06:18 PM
Wire/Fuse Size & Relay explanations SirGCal Audio, CB & Ham Radios, GPS, & Electrical 0 02-21-2007 11:43 AM
Which relay/fuse for Cruise? chrisvr6 Audio, CB & Ham Radios, GPS, & Electrical 0 03-15-2005 11:02 AM
