03-14-2012, 03:42 PM
#1
mine sounds like crap, blown out. they are hard to find and when you do they are expensive. does anybody know what size it is and can you put any ole sub in there?? thanks in advance
2004 jeep wrangler rubicon tj,1974 chevrolet corvette,2004 chevrolet corvette,2006 harley davidson fat boy
03-14-2012, 03:58 PM
#2
There is only one company that makes the sub
03-14-2012, 04:03 PM
#3
Ok so no other speaker will work in there?
03-14-2012, 04:17 PM
#4
Re-Member
So not true.
03-14-2012, 04:28 PM
#5
Quadratec carries a direct replacement.
1987 350 JEEP COMANCHE
Licence plate: FSTJEEP
2001 TJ SE, 31" KM2s, cragar d styles
JEEP: If i wanted a Hummer, I would have asked your sister
03-14-2012, 04:39 PM
#7
It's either 6" or 8"... Check out Crutchfield.com
03-14-2012, 05:50 PM
#8
This is what I replaced mine with. Works as well as the stock sub, but it can handle more power than the stock if you wire in your own amp.
http://www.ebay.com/itm/Bazooka-WF62...item5d2e624d4a
03-14-2012, 07:35 PM
#9
I replaced mine a few weeks ago, think it cost more to ship it than the sub itself cost. Got the sub for $9 and some change. And there are options out there, not just the quadratec junk.
03-14-2012, 08:08 PM
#10
Thinking about doing the same, but just using the enclosure with a new sub to free up my cargo space and remove the 12" sub and box.
don't want to use the OEM amp, have a sub amp already.
Anybody know what the best sub is that will fit in the console enclosure?
2004 LJ, Auto, Zone 3.5"/1.25"BL/MML/285 KM2s
2005 Rubicon, RE 4.5/3.5" SF, 285 KM2s sold
99 Sport, BB, BL, MML, 33s, sold
03-15-2012, 08:41 AM
#12
And who do think sells it quadrtek. I didn't say there was only one place to get it. All the ones you find are the same sub.
03-15-2012, 08:57 AM
#13
Re-Member
So your saying that the oEM with untreated paper cone and foam surround, quadratec drop-in with treated paper cone and rubber surround, the pyramid which requires that you remove material to make fit
, or the kicker 6.5 sub which also requires mods to fit are all the same?
03-15-2012, 11:02 AM
#14
Originally Posted by SinearOnyx
I just put one of these in a couple weeks ago, all I had to do was dremel out some of the plastic pieces inside the encloser to make it fit. Really cheap and simple. I also put some polyfil in it and it sounds pretty good for like $23 all said and done.
'80 CJ7, 304, T-176, Dana 300, Dana 30 and Model 20 w/ 4.10's, 35 X 14.5 Boggers, 6" Lift--FOR SALE!!
'04 Wrangler Sport, 6 cyl., 4 speed auto, 4" lift, 33X12.50
03-15-2012, 11:25 AM
#15
I guess my definition of direct replacement if different then yours. Cause the way I understand it is "direct replacement" means no modification required. As in a straight drop in. But I could be wrong.
