CB wont work - JeepForum.com
post #1 of 5 Old 10-16-2009, 06:37 PM Thread Starter
Boyjeepin
1980 CJ7
Xj CB wont work
Ok so I have a cobra 75WXST cb radio, was working fine, old antenna broke so I installed a new 4' Wilson FGT with a mount that I drilled into the rear above the tail light. Hooked up the SWR meter and the CB turned on and had no display and then turned off.
I tested the mount to make sure it was grounded and it was, cable and antenna all test fine. I am so confused, please help!
Everyone says never turn it on without antenna hooked up but Cobra says different, so I tried it and it doesn't turn on now. Not sure if it has a built in breaker that makes it not work without an antenna.
"Going to the woods is going home..."
1980 CJ-7: For Sale
2000 XJ: RIP
2001 XJ: MIA
Boyjeepin is offline
post #2 of 5 Old 10-16-2009, 07:01 PM
cico7
2007 XK Commander
Have you checked your inline fuses?
dont broadcast without the antenna, but turning it on wont kill it.
if you reversed the connection, you may have blown protective circutry.
check all fuses first.
I dont want to be your friend, request denied
8llllll8
cico7 is offline
post #3 of 5 Old 10-18-2009, 11:17 PM
SnowdogMarc
Real stupid question here....is the selector set to WX? If it is it blanks out the entire display on mine and has flipped me out a couple of times too.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #4 of 5 Old 10-19-2009, 09:30 AM Thread Starter
Boyjeepin
1980 CJ7
haha no. Actually I was messing with it yesterday and showing my friend how it didn't work and wouldn't you know it turned right on! Now I've just gotta get the SWR lower than 2.
1980 CJ-7: For Sale
2000 XJ: RIP
2001 XJ: MIA
post #5 of 5 Old 10-19-2009, 10:33 AM
Slithering_Joe
Are you are using an inline fuse like the one pictured here along side of the outlet?
These can open circuit very easily when there is tension pulling on the wire.
Use the blade type shown below.
Just a thought.
4.0L TJ
Slithering_Joe is offline
4wd wont work! dlowe Engines & Drivetrain 5 01-07-2010 06:39 PM
2 different CB wont work jeepwrnglr92 Audio, CB & Ham Radios, GPS, & Electrical 4 09-15-2008 06:49 AM
4wd wont work boondocksaint Engines & Drivetrain 5 08-22-2008 11:40 PM
Why Wont My Sub Work All The Time?????? DEERSLAYER1407 Audio, CB & Ham Radios, GPS, & Electrical 10 10-21-2005 09:42 PM
Backspacing???(pic wont work) TellyDSP Tires & Wheels 4 03-01-2003 07:55 AM
