CB transmits but doesn't receive - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > CB transmits but doesn't receive
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-26-2011, 01:47 PM   #1
GardenGnome5
So I was all set for my last wheeling trip. Met with the people I was going with and we agreed on channel 5 for communications. switched to the channel and proceeded to test... and nothing. I called up another rig on my phone and they said that they could hear me clear as day. I was trying to tune my CB all day but since I'm a complete newbie with CBs I had no idea what I was doing.
Anyone have any ideas of why I couldn't receive anything?
Thanks, Gnome.
96 Cherokee lifted, shoes, blah, blah, blah
89 YJ stock resto project
Coal Region 4x4
GardenGnome5 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 01:51 PM   #2
BeerMe
1975 CJ5
It's better to give than to recieve.
What CB band and model do you have?
BeerMe is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 03:05 PM   #3
99WJNM
was your squelch all the way up or was your volume all the way down
99WJNM is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 11:51 PM   #4
SnowdogMarc
Do you get any noise from the speaker at all...even when turned on initially? Could have a blown speaker but above post is highly likely whats wrong.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote Quick reply to this message
Unread 01-27-2011, 11:26 AM   #5
GardenGnome5
I have a Cobra 29 LTD.
Volume was up, squelch was tried in various positions. I didn't even get static when adjusting the squelch.
And it's not the speaker unless the internal and external speaker are blown because I tried them both.
Unread 01-27-2011, 01:18 PM   #6
Jon-joN
take it to a cb tech and get a recieve alignment. how old is this radio?
Jon-joN is offline   Reply With Quote Quick reply to this message
Unread 01-27-2011, 01:25 PM   #7
99WJNM
turn your rf gain knob all the way to the right is it turned left currently.
Unread 01-28-2011, 04:34 AM   #8
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check your Owners Manual ( http://www.cobra.com/Manuals/29LTDCLASSIC_MANL.pdf ) and make sure all the knobs and buttons are set correctly. Especially the PA/CB button and the CH 9 monitor button.
Did you look at the meter when the others were using their CB's ? You should see the needle on the S meter bounce back and forth when someone is transmitting.
The most common reason for a CB to receive transmitted signals but not have any sound output is a defective microphone or a mic wiring problem. If the mic in not connected, it is broken, or you have a broken/disconnected mic wire, the internal speaker will not function.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 01-28-2011, 07:06 AM   #9
GardenGnome5
I'm not sure how old it is. My dad gave it to me from his big rig but I don't know how long it was in use before that.
The RF knob was tried all the way up and all the way down and every position in between.
CJ7-Tim: When people tried to talk to me, the meter needle would bounce around, I just didn't get any sound. You think I should try a new mic?
Unread 01-28-2011, 10:47 PM   #10
Firedog13
Not trying to hijack, but I am having the same problem with my Jeep/radio. Good output but doesnt receive. Needle does move though when others key up. Recently had the radio peaked and tuned and the mic wiring re-done. Tried a different antenna (magnet base that was originally with the radio on a different vehicle) but nothing still. So I took the radio and plugged it into my truck in place of that CB. Everything works great. Back in the Jeep and can't get it to receive. I've pulled the coax out and will replace it next week. Did notice some worn areas on the outer coating. I'll be replacing it at the radio shop so as to learn from the experts.
I'll post up again once I make a trip to the radio shop. Hopefully things will be all squared away by then.
Firefighters Jeep Club
All gave some, some gave all.
Firedog13 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2011, 03:57 AM   #11
CJ7-Tim
CJ7-Tim's Avatar
You could try a new mic or have a CB shop look at the original one. Not all Cobra mics work on all Cobra radios. If you find a replacement mic, make sure it is for your specific model of Cobra CB.
Just and additional thought, if the mic is not original to the CB, open it up and see if it has a battery inside. It might or or it might not.
Unread 01-29-2011, 10:17 AM   #12
Richd1963
Richd1963's Avatar
Check Mic, also when you plug in an external speaker it disconnects the internal circuit. If an external speaker doesn't make any noise, revisit mic wiring or try another mic. Good luck.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2011, 09:43 PM   #13
GardenGnome5
Just in case anyone was wondering, I found the culprit and fixed it. there was a wire that had broken on the connector for my mic. re-soldered it and it was good to go.
