Cb swr - ch1 = 3 & ch40=1.1 - JeepForum.com
post #1 of 7 Old 11-28-2013, 08:22 AM Thread Starter
UncleWilson
UncleWilson's Avatar
Just to make sure I'm not missing something, is it possible to have a your SWR reading so far apart?
Channel 1 = 2.9-3
Channel 40 = 1.1-1.2
Does that mean I need to lengthen the antenna or is it something more serious?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #2 of 7 Old 11-28-2013, 08:40 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
When properly tuned a CB antenna will have higher reading on Ch 1 and Ch 40, and the lowest reading on Ch 20. Your results indicate that the antenna needs to be longer.
See the Tech Help pages at www.FireStik.com for SWR tuning help. The info applies to all brands and types of CB antennas.
If SWR on channel 1 is greater than that on channel 40, your antenna is considered to be "SHORT" and increasing the physical and/or electrical length of the antenna is required to correct this situation. If the antenna is tunable, move the tuning rod out to make the antenna longer. This condition is can also be corrected by adding a spring and/or quick disconnect to increase the physical height.
CJ7-Tim is offline
post #3 of 7 Old 11-28-2013, 09:10 AM Thread Starter
UncleWilson
Cool thanks. I went back out and got ch1 @ 1.6, ch40 @ 1.7, and ch20@ 1.3. I'll keep tuning it, but now I'm less worried about blowing up the radio.
post #4 of 7 Old 11-28-2013, 10:45 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by UncleWilson View Post
....got ch1 @ 1.6, ch40 @ 1.7, and ch20@ 1.3.
I would call it good, I doubt you will be able to improve these numbers. I would have no problems running any of my CB radios with these numbers.
CJ7-Tim is offline
post #5 of 7 Old 12-02-2013, 06:59 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That SWR sounds fine. I would simplify how you tune your CB antenna by just setting the channel to 20 and tuning for the lowest possible SWR there. That will give you the best overall SWR throughout the band. No need to retune it again on other channels like 1 or 40.
Gone on vacation until August 25.
Jerry Bransford is online now
post #6 of 7 Old 12-05-2013, 02:48 PM Thread Starter
UncleWilson
Thanks Jerry, I'll try that!
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #7 of 7 Old 12-07-2013, 02:13 PM
capt205
1983 CJ7
1.3 is fine.
capt205 is offline
