CB/Scanner antenna mount - JeepForum.com
post #1 of 3 Old 10-27-2001, 08:26 PM Thread Starter
evilpsych
evilpsych's Avatar
Post CB/Scanner antenna mount
hey guys.. have you seen that mount that moutns behind the taillight housing anywhere online? i cant seem to find it anywhere.. it's basically an L bracket that uses existing holes to mount the CB antenna.. i need a pair of them..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 10-28-2001, 11:47 AM
my litte red yj
Post
well i made my own bracket's for my scanner and cb ,out of 2 pieces of L bracket's bolted it to my tire stop and that was is it i will send a pic if you want!!! home made is the best
my litte red yj is offline
post #3 of 3 Old 10-28-2001, 12:13 PM Thread Starter
evilpsych
evilpsych's Avatar
Post
these were real slick.. you unbolted the taillight housing from the body and slipped the mount inbetween and it uses the same holes as the taillight..
A
can I use a police scanner antenna 4 ft. from a cb antenna? BigOrangeXJ Audio, CB & Ham Radios, GPS, & Electrical 11 05-08-2007 09:01 AM
Antenna for CB and Scanner? Chris_Walker Audio, CB & Ham Radios, GPS, & Electrical 7 02-06-2007 06:53 PM
Same Antenna for CB & Scanner? Bethlehem Audio, CB & Ham Radios, GPS, & Electrical 10 02-14-2005 08:41 PM
Window-mount scanner antenna any good? TXjeep97 Audio, CB & Ham Radios, GPS, & Electrical 3 12-18-2004 02:10 PM
Scanner antenna, suggestions? firefitr26 Audio, CB & Ham Radios, GPS, & Electrical 16 06-16-2004 10:41 PM
