CB radio tuning - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > CB radio tuning
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 08-12-2007, 11:38 PM   #1
surfgod04
CB radio tuning
Im sure this has been discussed, but how do you tune a CB radio antenna??
and whats the best configuration??
thanks alot!
97 TJ Sahara
3.5" RE lift
33 x 12.5 MT/Rs
K&N intake
6" KC Daylighters on the windshield mounts
skyjacker discos
[URL=http://members.cardomain.com/colins20 ]Just a couple pictures[/URL]
[COLOR=Red]MARYLAND JEEP CLUB MEMBER #1[/COLOR]
[COLOR=Blue]USN Jeep Club Hull #6[/COLOR]
surfgod04 is offline   Reply With Quote
Unread 08-12-2007, 11:57 PM   #2
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
search the forum for "swr meter" and you will find a ton of information such as how to use the commonly used radio shackl swr meter.
if you can't find anything here for whatever reason try google
shouldn't take more than bout 2 seconds of your time to find step-by-step directions.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Unread 08-13-2007, 06:09 PM   #3
alvinl
I found the info on Firestik's website to be more helpful than the instructions that came with my swr meter. Here is a link to Firestik's tech docs.
http://www.firestik.com/Tech_Docs.htm
alvinl is offline   Reply With Quote
Unread 08-13-2007, 06:43 PM   #4
FmrVette
FmrVette's Avatar
2008 XK Commander
thanks alot!
This might help get ya started:
http://www.firestik.com/Tech_Docs/Setting_SWR.htm
I got my SWR meter at Radio Shack, I think for $35 or so. Local 4x4 club might have one you can borrow. Truck stops usually have CB shops that can tune the antenna for a fee.
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels.” - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline   Reply With Quote
