CB Radio: High SWR - Page 3 - JeepForum.com
post #31 of 32 Old 05-05-2012, 03:41 PM
Necromancer_tat
Where'd all my money go?
Originally Posted by -sean- View Post
This thread should help others with similar issues in the future, seems like SWR issues are a common occurrence with Jeeps. You guys pretty much covered every possible problem that could have been causing the issue.
My CB usually has problems with the loose nut behind the microphone, lol!
Necromancer_tat is offline
post #32 of 32 Old 05-20-2013, 05:42 PM
aTX427
Good thread, but I have a question. I tuned the length of my Firestik FSII-3 antenna by setting FWD on channel 1 and 40 until they showed the same SWR, which came out to about 1.8-1.9. Is correct and is that as good as it gets?
aTX427 is offline
Installing radio, now no interior lights/no radio working? What fuse? Ford4Now TJ Wrangler Technical Forum 7 03-31-2012 07:49 PM
Lights dim and radio cuts out at high rpm Triscuits TJ Wrangler Technical Forum 11 02-21-2011 11:33 PM
Jet stage 2 for high speed high revs desert yj - is it worth it? dubaispy YJ Wrangler Technical Forum 17 04-11-2010 10:38 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
Is Radio wiring present if jeep originally came without a radio gary1 YJ Wrangler Technical Forum 14 02-07-2006 09:10 PM
