CB Radio: High SWR - JeepForum.com
post #1 of 32 Old 05-02-2012, 04:36 PM Thread Starter
-sean-
-sean-'s Avatar
1944 CJ2
CB Radio: High SWR
Installed a CB and no matter what I do, I can not get the SWR reading down below 2.8-3. I have tried the following.
Four different Antennas.
Four different radios hooked to different power sources and grounds.
Two different coax. (18', 15')
Replaced the Firering coax end on the 18' with a normal connection.
Re-grounded the antenna base with an extra strap, the mount is metal on metal.
Ran continuity test in every possible combination.
When I by-pass the entire antenna set-up and hook up a magnet mount antenna that I have I get 1.1-1.3 readings with that antenna in the same location as the other which is driver side hood near the windshield. I started out using the system in the link below.
http://www.stu-offroad.com/cb/cb1/cb-2.htm
-sean- is offline
post #2 of 32 Old 05-02-2012, 06:06 PM
robncar
robncar's Avatar
You might get more answers in the CB forum:
http://www.jeepforum.com/forum/f20/
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 32 Old 05-02-2012, 06:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A high SWR is, 99 times out of 100, the result of a mis-assembled mount that is shorting the antenna to ground. If you have the most common mount like shown below, make sure it is assembled per the instructions and like in the below illustration.
The usual problem is either the insulated shoulder washer is missing, installed off-center, broken, or not where it should be. The insulated shoulder washer's job is to prevent the antenna from touching the mount which would short it to ground.
Only the bottom of the mount, the "SO-239 Coax Connector" is supposed to have an electrical connection to the mounting bracket. The only thing above the mounting bracket that can touch the mounting bracket is the Insulated Shoulder Washer.
And moving this to the 2-way radio forum.
Jerry Bransford is offline
post #4 of 32 Old 05-02-2012, 06:53 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Not mounting the antenna on a hinged tire carrier or the tailgate helps also...
Knuckelhead is offline
post #5 of 32 Old 05-02-2012, 07:23 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Where are you parked when you test your swr's?
My newest build:
Necromancer_tat is offline
post #6 of 32 Old 05-02-2012, 08:01 PM Thread Starter
-sean-
-sean-'s Avatar
1944 CJ2
DOH! Yeah, I'm a newb.
Originally Posted by Jerry Bransford View Post
A high SWR is, 99 times out of 100, the result of a mis-assembled mount...
All good on the mount. Tried the Firestick FireRing and two different stud mounts for the standard PL259 connectors.
Thanks for moving this for me, I totally forgot about this sub-forum.
Mounted on the front fender.
At the end of my drive way, actually in the street which puts the Jeep about 30 yards away from the nearest building and there are no trees or power lines.
I have tuned lots of radios over the years and this one really has me baffled.
-sean- is offline
post #7 of 32 Old 05-02-2012, 08:11 PM Thread Starter
-sean-
-sean-'s Avatar
1944 CJ2
Here are a couple of pics of the mount that I am trying to use now.
-sean- is offline
post #8 of 32 Old 05-02-2012, 08:21 PM
Necromancer_tat
2015 JK Wrangler
What antennas are you trying? What SWR readings are you getting with them? Some of them really won't tune in very well no matter what you do.
My newest build:
post #9 of 32 Old 05-02-2012, 08:24 PM
Necromancer_tat
2015 JK Wrangler
And you said you ran a ground strap to the bolts that hold the mount to the fender? Have you tried running a ground strap from the bolt underneath the fender mount, to the body tub? I would also run a ground strap to the frame as well.
My newest build:
post #10 of 32 Old 05-02-2012, 09:22 PM
Ross
The fender mounts to the body. Both the fender and the place it mounts are probably painted. Even if you are bare metal to bare metal on the fender where the fender mounts there is allot of paint. Try grounding to the cowl.
-or-
It has to be the antenna and/or mount and/or coax and/or ground. But if you have tried a few different ones of these I would go back to the ground issue.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #11 of 32 Old 05-02-2012, 09:33 PM
JPNinPA
Are you using the same wire for the magnetic antenna and the mounted antenna? Is this perhaps a no ground plane antenna and wire?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #12 of 32 Old 05-02-2012, 10:03 PM Thread Starter
-sean-
-sean-'s Avatar
1944 CJ2
Thanks for all of the input guys!
The antennas that I have tried:
http://www.wearecb.com/store/wilson-...ck-p-3446.html (3.0-3.3 SWR)
http://www.wearecb.com/store/procomm...na-p-4098.html (SWR at the top of the range...4plus?)
http://www.wearecb.com/store/firesti...nna-p-200.html (2.8-3.2 SWR)
Also a 65" base load similar to the procomm above. (3.0-3.2 SWR)
And the Lil Wil Wilson magnet mount which is a stand alone unit with its own RG58 attached to it. And that one works great. (1.1-1.3 SWR)
My ground strap runs from the bottom of the mount inside and underneath the fender and is attached to one of the stainless bolts. It runs to the factory grounding bolt that is on the firewall which has multiple OEM grounding straps attached to it.
RG58 is new (Firestick) and all PL259 connectors are new. No coax is coiled anywhere.
I have to be missing something.
-sean- is offline
post #13 of 32 Old 05-02-2012, 10:06 PM
Necromancer_tat
2015 JK Wrangler
I'm not a big fan of any of the antennas you listed. I'd run a wilson 2000 or a K40 antenna and be done with it. I've never had any luck tuning those antennas that you posted.
My newest build:
post #14 of 32 Old 05-02-2012, 10:42 PM
Jerry Bransford
Administrator
Firestik antennas, particularly the FS series with the tunable tip, tune up just fine. I've probably tuned 50+ Firestik antennas and once they were installed properly, I never had any problem getting any of them down to sub-1.5:1 and most closer to 1.2:1 SWRs. It's not the antenna itself causing this SWR problem.
If you can't get an antenna's SWR down to an acceptable number, when talking about a commerically manufactured antenna we typically use on our Jeeps, it's not very darned likely it's the antenna itself. Look at the mount to see if it was misassembled, see if the antenna's mount is able to get an adequate RF ground (not just a simple DC ground), look for a poorly soldered connector, etc. but don't spin your wheels and blame the antenna itself or the brand of antenna.
post #15 of 32 Old 05-02-2012, 10:49 PM Thread Starter
-sean-
-sean-'s Avatar
1944 CJ2
That makes two of us!
Funny you mentioned K40, I almost bought this one when I first got started doing this project.
-sean- is offline
Installing radio, now no interior lights/no radio working? What fuse? Ford4Now TJ Wrangler Technical Forum 7 03-31-2012 07:49 PM
Lights dim and radio cuts out at high rpm Triscuits TJ Wrangler Technical Forum 11 02-21-2011 11:33 PM
Jet stage 2 for high speed high revs desert yj - is it worth it? dubaispy YJ Wrangler Technical Forum 17 04-11-2010 10:38 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
Is Radio wiring present if jeep originally came without a radio gary1 YJ Wrangler Technical Forum 14 02-07-2006 09:10 PM
