CB radio choice feedback, another CB question - JeepForum.com
post #1 of 25 Old 12-12-2012, 07:55 PM Thread Starter
diddy2003
So my mom was asking what I wanted for Christmas for the Jeep, and I decided on this:
http://www.rightchannelradios.com/un...ad-cb-kit.html
I was going to go with the Uniden Pro 520XL, Firestik FS 4 foot, and the teraflex tail light mount for the passenger side. It doesn't say if the antennae is tunable, but I would assume it is.
So what do you think? The only issue I have is that I don't have much room left to fit in the garage without a big CB antennae. So, would you go with a quick disconnect or a spring?
http://www.rightchannelradios.com/fi...isconnect.html
http://www.rightchannelradios.com/fi...na-spring.html
There is also a mount like this, but it is pretty expensive
http://www.quadratec.com/products/96080_50.htm
diddy2003 is offline
post #2 of 25 Old 12-12-2012, 10:00 PM
1998zj
I have that radio and a 4' Firestik and it won't fit in my garage. If you wheel around trees they will break it off because it doesn't flex. I got a 3' Everhardt flexible I use when I wheel and it will just fit under the garage door.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 25 Old 12-13-2012, 07:32 AM
Ross
I have the 4ft version of the Everhardt and it is very flexible. I also have it mounted onto a spring. It has been a great antenna for me and performs really well. I tie mine down to fit in the garage.
I have broken (ripped up the tips)a couple fire sticks over the years. The fire sticks I have had have been more ridged. Fire stick may make a more flexible antennas than the ones I have had. Many here seem to like fire sticks.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #4 of 25 Old 12-14-2012, 10:30 AM
JPNinPA
If your using this for wheeling and for most com, you do not need the extra length. In most cases. ESP if you have a soft top and no large metal objects near the antenna area. A 2 ft antenna will perform well though be a bit harder to tune. You just make smaller Adjustments. A three foot with no spring is what many use on the tail light mount.
And I'd go with the 520xl.
http://www.firestik.com/Tech_Docs.htm
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #5 of 25 Old 12-14-2012, 11:10 AM Thread Starter
diddy2003
So I just took a tape measure out to see what would happen with either a 4 foot or 3 foot from the tail light. A 3 foot would work no problem. It's about as high as the soft top. A four foot would require a disconnect or something. I was told a four foot is the way to go for tuning.
post #6 of 25 Old 12-14-2012, 11:19 AM
Ross
I have a loop so I can tie down my 4 foot antenna if needed or I can tuck it under then rear flap on my soft top. It was easy to tune. I am not sure why a 4 foot would be any easier than a 3 foot to tune. When I am out on the trial it stands up, I only put it down when I am in and out of the garage or not using the CB. On the trail I keep it up. I can reach out better than other in my group, the Everhardt can take a beating compared to the fire sticks I had.
Ross is offline
post #7 of 25 Old 12-14-2012, 11:22 AM
1998zj
I had no problems tuning a 3'. I have no problems talking to who I need to with it either.
1998zj is offline
post #8 of 25 Old 12-14-2012, 12:50 PM
Ross
As long as your CB is setup correctly a 2 foot antenna would work better than along whip antenna not setup correctly. Tuning and grounding your antenna correctly are the most important thing when it comes to performance.
Ross is offline
post #9 of 25 Old 12-14-2012, 01:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yes the Firestick FS series of antennas are all tunable. To me, the 4' is too tall for that mounting location, I'd go no taller than the 3' and actually, I converted from my previous Firestick FS-3 to a FS-2 to clear my garage door. Both the 2' and 3' FS Firestick antennas tune fine, my 2' SWR is probably at about 1.2:1 which is very good. For offroad use, even the 2' works extremely well, I noticed zero performance difference offroad after converting from the 3' to the 2' Firestick which is a very good offroad antenna.
Take pains to correctly assemble & mount the antenna mount, particularly make sure the insulated shoulder washer that is part of the mount gets properly installed in the right location. When that shoulder washer is left out or is installed incorrectly, the antenna won't work properly & it will be impossible to tune the antenna to make it perform well. Its job is to electrically insulate/isolate the antenna itself from the the mount which is crucial to the antenna working properly.
Good decision on the Uniden PRO-520XL, that's a great radio that is pretty much bulletproof. I've had that exact radio in two different Wrangler TJs.
Jerry Bransford is offline
post #10 of 25 Old 12-16-2012, 07:06 PM Thread Starter
diddy2003
Ok, so I just ordered it up. I went with the Uniden 520 XL, Firestik 3 foot, and teraflex passenger side tail light mount. I can't wait to finally have a CB. It should be great. Thanks for all the help.
I also got one of these:
http://www.retrosoundusa.com/products/details/id/260
I've never had a radio in the jeep before. Its going to be nice to have since I have been driving it more and more lately.
post #11 of 25 Old 12-16-2012, 07:38 PM
Jerry Bransford
Administrator
Be aware you will (!) need to grind some of the powder coating off from the Teraflex mount for the mount's required ground connection so the antenna will work properly. Grind a small circle of powder coating away from the bottom of the mount around the antenna mounting hole so the antenna mount's washer & nut will touch bare metal. You'll need to make sure the Teraflex mount is also solidly/electrically connected to the tub by either grinding more paint/powdercoating away so it has a bare metal connection to the tub, or you'll need to connect the Teraflex mount to the tub with a braided ground strap.
The antenna will NOT work properly with the Teraflex mount if you don't grind the powder coating away so the ground connections can be achieved. I had another Jeep in my garage Sunday with a high antenna SWR problem and I traced it down to that exact issue... which has been an issue with Tera's antenna mounts since they started selling them.
post #12 of 25 Old 12-16-2012, 10:35 PM
JPNinPA
Jerry is correct on the terra flex mount.
You will also need:
http://www.rightchannelradios.com/cb...nt-pl-259.html
Borrow or buy:
http://www.rightchannelradios.com/sw...per-cable.html
And read and understand these :
Power and ground the radio to the battery 'Period' antenna is different.
http://www.firestik.com/Tech_Docs/Te...Continuity.htm
http://www.firestik.com/Tech_Docs/Setting_SWR.htm
JPNinPA is offline
post #13 of 25 Old 12-18-2012, 08:47 PM Thread Starter
diddy2003
Thanks for the heads up. I've heard that about those mounts before. I hope the set-up works well. I don't see why it wouldn't. I am going to have a buddy, who is really good with CBs, help install it. I can't wait to finally have a CB and know what's going on while on the trial.
CJ7Build
www.jeepforum.com/forum/f8/1984-black-cj7-build-my-never-ending-project-addiction-1202820/
post #14 of 25 Old 12-18-2012, 08:50 PM Thread Starter
diddy2003
You will also need:
Borrow or buy:
The kit doesn't come with a stud mount? I thought it had everything needed to install a working cb. I know it comes with a SWR meter.
CJ7Build
post #15 of 25 Old 12-19-2012, 08:55 AM
Jerry Bransford
Administrator
A couple of the mounts show a stud mount, others don't... I'd verify whether the mount you choose includes the required stud mount. Of all those mounts, I'd go for the Teraflex mount... 2nd from the right... which is one that doesn't specifically show that it includes a stud mount.
