Which CB Radio - JeepForum.com
post #1 of 15 Old 11-30-2013, 09:32 PM Thread Starter
408jeeper
Which CB Radio
Hey,
I was wondering what's a good cb radio. I want something that will get the job done but not break the bank.
how the cobra 19 ultra?
also whats a good antenna?
408jeeper is offline
post #2 of 15 Old 11-30-2013, 09:45 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
I went with Uniden PRO520XL and a 3' Firestik on a spring, pretty happy with my setup.
May TJ of the Month 2015
TexasTJ is offline
post #3 of 15 Old 11-30-2013, 10:31 PM Thread Starter
408jeeper
Looks pretty good! whats your power source for the radio?
post #4 of 15 Old 11-30-2013, 10:34 PM
LukeADukes
Any other places to mount the CB? The top part of the dash is my favorite spot to put my phone while playing the radio....
Always look both ways before crossing the stream.
LukeADukes is offline
post #5 of 15 Old 11-30-2013, 11:15 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
The battery, ran my wires through the drain plug in the firewall behind the pedals.
I used to use that too, if you mounted it towards one side of that tray you should still be able to fit your phone up there. I usually use a cup holder for my phone now.
Alot of people mount it on the side of their console by the shifter, behind the console, or overhead, or on the top left part of the dash (above and to the left of the gauge cluster).
Ideas in here:
http://www.jeepforum.com/forum/f20/c...ep-tj-1513277/
http://www.jeepforum.com/forum/f59/c...ons-tj-948785/
TexasTJ is offline
post #6 of 15 Old 12-01-2013, 12:06 AM
wjidaho
Or if your a crazy wj guy I put mine here
And I am running a Cobra 19 ultra III, with a 3ft firestik, so far works good on the trail and even on the freeway.
My build thread
wjidaho is offline
post #7 of 15 Old 12-01-2013, 06:38 AM
WranglerPete
I also went with the Uniden Pro520XL and the 3' Firestick. I have mine mounted to the left of the steering wheel using the Rugged Ridge mount. It just fits, but it fits.
WranglerPete is offline
post #8 of 15 Old 12-01-2013, 09:59 AM Thread Starter
408jeeper
How the radio? You like it? How about the antenna. Is 3' enough or 4'?
post #9 of 15 Old 12-01-2013, 04:56 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any Uniden, Cobra, or Midland CB will be fine. Simply pick the features or the size you want to have. I think RF Gain and some switchable noise circuitry are necessary. As rule, the taller the antenna you use, the better the CB works. Choose whatever size fits on your 4x4 trails and wherever you need to park. 3-4 ft CB antennas are the most commonly used. I prefer FireStik-II FS tunable antennas.
CJ7-Tim is offline
post #10 of 15 Old 12-01-2013, 10:32 PM Thread Starter
408jeeper
I decided I'm going to go with the uniden pro 520xl
post #11 of 15 Old 12-01-2013, 10:36 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
^ Good choice, I'm with CJ7-TIM on the Firestik II 3'. Same setup I have.
TexasTJ is offline
post #12 of 15 Old 12-01-2013, 11:03 PM Thread Starter
408jeeper
If I go with a firestik II 3'. How exactly do you tune it? Do I need to buy a device to tune it? Or can I do it some other way?
post #13 of 15 Old 12-02-2013, 08:13 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
Yea you'll need an SWR meter, hook up the coax cable from the antenna to one plug and a small coax cable (usually included with SWR meter) into the back of the CB. Then do the tuning stuff on it and adjust the antenna as needed.
TexasTJ is offline
post #14 of 15 Old 12-02-2013, 08:22 AM Thread Starter
408jeeper
Alright. Any swr meter will work right
post #15 of 15 Old 12-02-2013, 09:16 AM
Bmel17
correct. I just watched a youtube on how to work it and tuned it in. Pretty easy! mine came out to 1.4-1.5
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
