CB Question - JeepForum.com
post #1 of 6 Old 09-28-2011, 08:12 AM Thread Starter
ArmyVet717
CB Question
Have had my Cobra 29 Limited installed for a few weeks and yesterday, I noticed that when I key up my antenna light is no longer lighting up. I re-calibrated and am just around 0-1 on the SWR meter. Looked through the instruction manual and it does not say whether the light should come on or not when I key up. It did before, so now I am totally confused!
Thanks!
'96 Grand Cherokee Laredo, 5.2L, NP242 Swap, Closing in on 300K miles, 4.5" RE lift, Tow Pig: 04 Dodge Durango SLT, 4.7L
http://www.facebook.com/#!/smontgomery717
ArmyVet717 is offline
post #2 of 6 Old 09-28-2011, 03:10 PM
hndswthtshdws
Ant light should not come on, it indicates your SWR is way off. The tx light should turn color/on.
hndswthtshdws is offline
post #3 of 6 Old 09-28-2011, 03:49 PM
JPNinPA
If you are using the SWR meter on the radio, they are not that good. Best they will tell you is if your in the ballpark or if your antenna system is shorted. Second I think you mean 1:1 not 0-1.
How are you checking SWR?
On the 29 there is a TX/RX light that should be green and change to pink or red when you press the PTT button on the mic.
http://www.firestik.com/Tech_Docs.htm
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 6 Old 09-28-2011, 05:35 PM Thread Starter
ArmyVet717
I only used the SWR calibration that is built in to the CB. My TX/RX light does go from green to red when keyed up. This afternoon I noticed that depending on my location (buildings or open area) my ANT light would come on. I am picking up people in Arkansas and Texas and everywhere in between, but I think I will get an external meter to see if it needs some fine tuning.
Thanks for the info!
post #5 of 6 Old 09-29-2011, 04:42 AM
JPNinPA
Yes the antenna light comes on when it senses a high SWR reading while transmitting. And closeness to buildings or tall structures will effect SWR.There is nothing you could do about the effects of buildings and tall structures. Just be sure when you set your SWR you are in an open area. There should be a little blurb about the light in the manual."Note Antenna Indicator LED will
illuminate when TX if SWR is high."
Is this turning on even when you are not transmitting?
JPNinPA is offline
post #6 of 6 Old 10-04-2011, 01:19 PM Thread Starter
ArmyVet717
That I have noticed. When I am around buildings or in the "city", I get the light flickering... When I am on the highway it flickers every once in a while, but not bad. It does not flicker when not keyed up. Even in the city, it is not constant, it comes and goes...
Newbiee Question?? - grand cherokee thumping question geoff6194 Engines & Drivetrain 0 10-21-2009 11:13 PM
Width of rim question,,,,and **** Cepek rim question. UPSucks Tires & Wheels 3 09-15-2007 09:19 AM
OME vs BDS Question. And Gearing + Tire Question mferrari Tires & Wheels 6 01-15-2006 12:43 AM
Wiring question and meter question Highlander357 Audio, CB & Ham Radios, GPS, & Electrical 4 12-29-2005 01:20 AM
My 2" BB lift question - in depth, and HUGE question WheelinTJ2004 Tires & Wheels 11 02-01-2005 07:17 AM
