CB problem - JeepForum.com
post #1 of 12 Old 11-04-2001, 09:01 AM Thread Starter
mytjnamedrex
Post CB problem
Ok i have a problem with my CB and cant figure it out. After I went offroad yesterday i turned my CB off and went to the powerwasher...When I was done i turned on my CB but no sound. The antenna was the only thing that was outside and everything was tight. I had the top on so nothing got wet on the inside. All connections are tight and now i just get the channel light but when i press the MIKE button i get TX come up so i dont think it involves the mike. I have a mavon CB and a 3 ft. fiberglas antenna that i picked up at radioshack(no laughing it was an impulse buy) Well sorry its so long but does anyone have any ideas???
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 12 Old 11-04-2001, 11:56 AM
evilpsych
evilpsych's Avatar
Post
turn your squelch down.. duh..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 12 Old 11-04-2001, 12:38 PM Thread Starter
mytjnamedrex
Post
its all the way down..........im not that stupid! It worked this morning though.. does water affect it even though the connections are tight? Ive used it in the rain with no problems b4..
post #4 of 12 Old 11-04-2001, 12:41 PM Thread Starter
mytjnamedrex
Post
also im thinking about the synthetic blinker fluid... whats the best kind lol I think my muffler bearings are about worn out cause theres this sound that like comes from like the pipe at the back and it didnt do it like earlier LOL i know its an old joke but its just too funny
post #5 of 12 Old 11-04-2001, 01:31 PM
my litte red yj
Post
check to see if the switch for pa /radio is not in the pa mode!!
my litte red yj is offline
post #6 of 12 Old 11-05-2001, 05:03 PM Thread Starter
mytjnamedrex
Post
i dont have a PA. It will work from time to time but when im going down the street at above 25mph i lose reception. It comes and goes and ive checked and rechecked everything...the coaxial cable isnt bent or anything. Could it be an antennna and how could i check w/o getting a new one??
post #7 of 12 Old 11-06-2001, 05:53 PM
evilpsych
evilpsych's Avatar
Post
what kind of antenna do you have? a decent screw-in jobby or a magnetic mount?
A
post #8 of 12 Old 11-06-2001, 06:18 PM Thread Starter
mytjnamedrex
Post
a screw in..
post #9 of 12 Old 11-06-2001, 09:32 PM
evilpsych
evilpsych's Avatar
Post
hrmm check the antenna's ground
A
post #10 of 12 Old 11-13-2001, 05:26 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Post
You might want to check Craig's website. He is into Jeeps and has been the "gawd of CB's" for around 25 years (full time job). He has some great information on his site regarding CB's and antenna and such ..
You might just find your answer there .. I know I found many of my answers there
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #11 of 12 Old 11-17-2001, 04:01 PM
ukjeeping
ukjeeping's Avatar
Exclamation
Go back to RadioShack and have them put an SWR meter on your cb. Water can get down in coax causeing a short to ground
'02 Solar Yellow, 4.0, 5-speed, 30" tire/rear D44. Landrover recovery team Coonass stuck in UK
ukjeeping is offline
post #12 of 12 Old 11-20-2001, 03:07 PM Thread Starter
mytjnamedrex
Post
im thinking of investing in a longer antenna to mount on the bumper for a little better reception and i took it to radioshack and calibrated it. It works fine offroad but i find that at times it has problems going on the street. Im hoping a better antenna will help reception as well as signal reliability. Thanx
Is my amp the problem???? hammy0107 Audio, CB & Ham Radios, GPS, & Electrical 6 02-09-2009 05:38 AM
Sub problem LiBMXr1390 Audio, CB & Ham Radios, GPS, & Electrical 7 03-26-2008 08:28 PM
arb problem-----help 2cjs Engines & Drivetrain 7 07-10-2007 02:53 PM
Amp problem captain_ruggy Audio, CB & Ham Radios, GPS, & Electrical 23 08-08-2006 12:56 PM
cb problem... JeepMud02 Audio, CB & Ham Radios, GPS, & Electrical 9 10-30-2003 12:33 PM
