CB Power interrupting Stereo Memory - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & HAM Radios, GPS, & Electrical. > CB Power interrupting Stereo Memory
The Boss is away but Erin is here to STAY with a F.Y.S. SaThe Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-17-2015, 02:02 PM   #1
Jeeperez
I couldn't find a related post.
I installed my Cobra DXIV CB radio in my XJ and took power from the KEYED power from the Stereo System. I ran a dedicated ground to the firewall. Now, my Stereo does not hold memory. The Memory line is confirmed to have power, all fuses are good.
So the head unit is receiving memory power all the time, the only thing that changed was borrowing power out of the keyed line to bring to the CB. I already know that straight to the battery is a better connection, I had it on my YJ but kept forgetting it on overnight. I wanted a keyed power just like the stereo. I don't understand what was done wrong power wise, so somebody school me!
Matt
[QUOTE=daverubino;10133980]Sell your YJ???? Why would anyone do that. You dont sell YJ's you just keep them until they become parts heeps for your next one.[/QUOTE]
Jeeperez is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 04:43 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The logical solution is to use another switched circuit to power the CB.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 06:45 PM   #3
Jeeperez
What other switched circuit is there? Preferably with easy access to wire to
Matt
Unread 02-18-2015, 09:43 AM   #4
prerunner1982
1993 XJ Cherokee
There may be slots in the fusebox that are switched and always on. They may be marked, the ones on my 93 XJ are but a multi-meter or test light could confirm.
Jon
KF5WUF
1993 XJ Sport 2 door 4x4
Red Dirt Jeeps
prerunner1982 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 11:12 AM   #5
CJ7-Tim
CJ7-Tim's Avatar
Yup, poke around in the fuse box with a multi-meter or test lamp and find a switched circuit.
Unread 02-18-2015, 01:55 PM   #6
Jeeperez
Okay thanks guys, i'll see what I can get.
In the meantime, can someone please explain to me what is wrong with the circuit I wired up originally? Doesn't make much sense for the radio to lose memory when the memory power stays connected. I only borrowed power from the keyed. Could it be the dedicated ground run to the CB? Would that somehow be grounding out the radio? Doesn't make sense to me
Matt
Unread 02-20-2015, 07:09 PM   #7
Jeeperez
Bump for an explanation
Matt
Unread 02-20-2015, 07:18 PM   #8
Sda1c
What others have posted is what needs to be done to fix but there are a couple of possibilities for the failures. I would speculate that the either the RF from the radio is interfering with the inner boards and chips of the radio or the voltage is dropping just enough with the key of the mic to foul the radios memory. If your SWR's are off you can cause all sorts of issues. Can you talk over the intercom at McDonalds? If so, and you don't have a linear amplifier, then you need to reset your standing wave ratio.
Sda1c is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 10:02 PM   #9
Jeeperez
The mic has never been keyed. It does it the moment I power it up via the ignition key. I'm gonna find an alternate source of power as soon as the weather cooperates.
I don't go to McDonald's but I'll grab my meter and check the SWR. Not sure if it's related or just how the CB works, the CB itself doesn't hold channel memory I guess you could call it that. When shut off and then on it always returns to Channel 1.
Matt
Unread 02-21-2015, 10:52 AM   #10
Sda1c
If your not keying the mic I'd say the cb is draining all power from the memory circuit in the radio when the key is turned off. Isolation is best. have you tried a diode to limit back current? An LED in line will get you started....
Unread 02-22-2015, 09:56 AM   #11
Jeeperez
I haven't tried anything inline, except for an inline fuse between the connection and the CB. I might try adding a diode before finding an alternate power source.
Matt
Unread 02-22-2015, 11:17 AM   #12
The_War_Wagon
2007 XK Commander
As the CB forums all say - DRILL THAT HOLE!
Time to wire your CB direct to the battery, which makes more sense anyways. Find a safe spot in the firewall, drill your hole, and plug the open space around the wires with a generous helping of RTV when you're done!
'07 Commander, Rocky Mountain Edition, 67k miles, & looking for advice!!!
The_War_Wagon is offline   Reply With Quote Quick reply to this message
Unread 02-22-2015, 03:29 PM   #13
Sda1c
+1^. I'm installing my 2950dx now and there is no way I would consider finding any source beside the batt. But if you must- a diode my solve your problems. FYI If you happen to use a linear amplifier don't even consider an alternate source than direct to the battery.
Unread 02-26-2015, 10:34 AM   #14
Jeeperez
My original thinking was to keep the CB on the 'radio' circuit from the fuse box, and also to be switched with the key because I always forgot it on in my YJ.
Matt
Unread 02-26-2015, 11:20 AM   #15
CJ7-Tim
CJ7-Tim's Avatar
There are multiple switched circuits in the fuse box.
