CB newbie - JeepForum.com
post #1 of 11 Old 09-08-2004, 04:34 PM Thread Starter
myuserid
Question CB newbie
I am interested in buying a cb (with noaa weather bands) on it. I have zero experience with cbs.. I hope someone here would be kind enough to guide me in my purchase.
Heres my requirements:
1. Small size - I dont want a big mama jama cb box unit (concealable)
2. $100 or less (prefer less)
3. Must have some Noaa weather bands (my bootie was just kicked by frances)
I have no idea what brands are good or what to look for. Whats the best place to buy inexpensive cbs from? Lastly, any info on antennas and mounting it would also be greatly appreciated.
My jeep is a daily driver, I just want the cb for a alternate mode of communication and for emergencies.
Thanks!
[myuserid]
myuserid is offline
post #2 of 11 Old 09-09-2004, 07:39 PM Thread Starter
myuserid
Ok, since I had time today... I did a bit of research and found a Cobra 18 WX ST II which falls into all of the requirements I have.
Does anyone have experience with this cb?
myuserid is offline
post #3 of 11 Old 09-09-2004, 09:33 PM
supersly_jones
my buddy has one...she loves it...i love it...you won't be dissapointed....she got the blue one....lol...
supersly_jones is offline
post #4 of 11 Old 09-10-2004, 01:08 PM Thread Starter
myuserid
Instead of the Cobra 18 wx 2 I ordered a Cobra Remote 75 WXST NOAA Weather CB Radio. This seamed easier to hide then the other one.
I also ordered:
4' firestik II
Mounting bracket from Arizonarockyroad.com
Hope install goes well.
Thanks for the help...
myuserid is offline
post #5 of 11 Old 09-13-2004, 11:24 AM Thread Starter
myuserid
Just picked up the following:
Firestik II
12' of cable
swr meter
3' jumper for swr
Waiting on cb and antenna mount - damn.. I cant wait.
sorry for the mindless post
Cheers -
myuserid
myuserid is offline
post #6 of 11 Old 09-17-2004, 10:25 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Whats happening with the CB install ?
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #7 of 11 Old 09-18-2004, 07:40 PM Thread Starter
myuserid
I started installing today, should be done tomorrow. It went pretty smoothly. Ill post some pics in the next day or so.
Cheers -
myuserid
myuserid is offline
post #8 of 11 Old 09-19-2004, 01:12 PM Thread Starter
myuserid
Ok, install is finished and pretty clean.
Here are some pics...
Firestick II 3' antenna on arizonarockyroads antenna mount.
Routing wire from firestick/antenna mount to tailgate.
Side view
Rearview
looking down between spar and tailgate
Antenna wire coming out of tailgate into Jeep
Excess wire so when i open and close tailgate there is some slack.
I just used zipties to hold cable inder window rails
Routed cable between rollbar and passenger door frame.
I then routed the cable down behind the door strikeplate support and down the side of the door frame.
Continued in next post...
Cheers -
myuserid
myuserid is offline
post #9 of 11 Old 09-19-2004, 01:18 PM Thread Starter
myuserid
I then routed under the bottom of the door frame and zip tied the cable
Routed up the side of door frame behind door starp pin and into dashboard. Then I zip tied it to some other cables behind glovebox.
Then dropped the wire down to the center console. Note the red wire is the positive power wire which i ran up to a switched outlet. I used the socket that is located next to the 12 volt light socket
I took the dash apart and wired the cb into the 12 vlt switched accessory socket (the one without the writing).
The cb is easy to uninstall and reinstal. The remote part of the cb is hidden under the change box (above gear shifter) I then can even stuff the cb in there when i leave the vehicle. More then likely I will take it with me or leave it in the trunk when not in use.
Hope you like it.
Cheers -
myuserid
myuserid is offline
post #10 of 11 Old 09-20-2004, 07:12 AM
Scrambler82
1982 CJ8
Nice Job...
Glad it worked out.
How was the SWR on the system ?
Later,
Scrambler82
post #11 of 11 Old 09-20-2004, 12:40 PM Thread Starter
myuserid
Originally Posted by NnF
Nice Job...
Glad it worked out.
Later,
Glad you liked it.
I was getting 1.3 - 1.5 on the swr... i just said screw it and left it at that after about 20 minutes of fidgiting...
Cheers -
myuserid
myuserid is offline
Newbie needs help Fullthrottle Tires & Wheels 5 11-19-2007 12:36 PM
newbie needs help attk11 Tires & Wheels 2 05-12-2007 08:24 PM
newbie flipoverplynmud Street Jeep Forum 20 08-13-2006 02:34 PM
Newbie Needs Help! njhunter47 Audio, CB & Ham Radios, GPS, & Electrical 1 07-14-2004 10:09 AM
Help the Newbie! Please. Randy_Ippolito Tires & Wheels 9 10-13-2003 10:01 PM
