Quantcast CB and my RPM gauge - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > CB and my RPM gauge
FREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 09-23-2002, 01:58 PM   #1
Dan Morera
CB and my RPM gauge
Is it normal that when I speak on my CB, my RPM gauge moves up and down just following what I say. You know it jumps with my voice???? Do I have to worry about this???
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline   Reply With Quote
Old 09-23-2002, 04:34 PM   #2
Devious
Hobo
Devious's Avatar
1996 YJ Wrangler
I had the same problem in mine when I used a device that would some how "amplify" my signal. I didn't notice any negative effects other than that.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline   Reply With Quote
Old 09-23-2002, 04:38 PM   #3
Dan Morera
Well, my CB is just a basic one without any mods or gadgets, so I don't have anything to worry about, right? Did you get rid of the thing?
Old 09-23-2002, 04:46 PM   #4
Devious
Hobo
Devious's Avatar
1996 YJ Wrangler
Do you have your power wire for your CB wired directly to your battery? I had mine wired this way and found out that it was to close to the coil where I had my tach wired into. I still have everything in my Jeep as of right now. I still don't see it being a problem. After I moved the power wire I never had this problem anymore.
Old 09-23-2002, 04:47 PM   #5
Dan Morera
I got it from the battery.
Old 09-23-2002, 04:52 PM   #6
Devious
Hobo
Devious's Avatar
1996 YJ Wrangler
I thought you might, I would just move the wire away from the coil and see what happens. It should quit doing it after that. Do you get alot of engine noise through your CB?
Old 09-23-2002, 05:07 PM   #7
Dan Morera
I don't know what engine noise sounds like, on the CB, it's firts one.
Glock Forum
