cb mounting spots and cable length - JeepForum.com
post #1 of 6 Old 09-15-2004, 01:06 PM Thread Starter
kennyb
kennyb's Avatar
Question cb mounting spots and cable length
I have a cb and I put the antenna on my tailgate right behind my spare, now I was wondering where everyone else was putting their cb radios inside, I heard of some people putting them right under the vents for air condition. Right now I just have my sitting on the side of my drivers seat can't really hear it because the seat muffles the speaker. also I was wondering how much length of cable I should use, I heard of people saying don't use under 13ft cause it distorts the signal, but then again I read that you should use around 18ft or longer. I know I can run it under my tub as long as its not coiled up. let me know what you think or any suggestions
97 ZJ limited 5.2L
kennyb is offline
post #2 of 6 Old 09-15-2004, 01:37 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
I have mine mounted where the ash tray use to be, I dont smoke, so it wasnt a problem.
As for cable length, hmm I've heard so many stories as to what length is better that I said the heck with it and went with 18'.
You can pick up a cheap external speaker at a truck stop or online to help you hear the CB better.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 6 Old 09-15-2004, 04:10 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
the proper length is whatever the distance from your antenna to your CB is...
for some "enlightening" reading, try this out:
http://www.stu-offroad.com/misc/myth-1.htm
IF your CB has an external speaker output, that is definitely the way to go...the speakers usually run <$10...
I mounted my speaker directly above my head, tied to the rollbar "corner"...I run a Safari top or hard top all the time, so rain is no issue for it...
An external speaker was a MUST for me, as I can't hear the standard speaker at all, due to my mounting location:
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 6 Old 09-15-2004, 08:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The 18' cable length recommendation propagated by some is nothing more than a hard-to-kill myth, really.
Use the amount of cable needed to make the connection and properly route it and that is all you need to be concerned with. If you want to use 18' because it came in that length but you need to coil up the excess, go for it... but the 18' length won't help performance in the least. In fact, though the loss is negligible at this length comparison, a 16' length would result in less loss than the 18', and a 10' etc., would give even less loss.
Getting
Jerry Bransford is online now
post #5 of 6 Old 09-15-2004, 09:05 PM
slickwillie
slickwillie's Avatar
I just bought 12' of cable yesterday from a CB shop. The guy said length didn't really matter. It was just the right length to run from the tire carrier bumper on the pass rear to the cb under the middle of the dash.
1983 CJ7 AMC 360, T-5, Dana 300, Dana 30, AMC 20
Warn XD9000i, RE hand throttle, 1" body lift, OBA
slickwillie is offline
post #6 of 6 Old 09-20-2004, 05:04 PM
ncb76
ncb76's Avatar
Mine is mounted in the glove box. It's worked well for me. Keeps it out of sight when not in use. You can check here for pictures:
http://www.imagestation.com/album/?id=4286376895&idx=4
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
Fire Ex. Mounting spots on TJ??? turkish6 General Jeep & Off-Road Equipment 15 09-06-2011 07:11 PM
RB1 and CD changer cable or Song/Artist cable? thebq Audio, CB & Ham Radios, GPS, & Electrical 5 09-06-2007 01:43 PM
CB antennas /mounting spots YCP4x4 Audio, CB & Ham Radios, GPS, & Electrical 8 11-21-2006 06:34 PM
Infinity basslink mounting spots.. Roll Tide Audio, CB & Ham Radios, GPS, & Electrical 4 05-17-2006 01:48 PM
cb antenna mounting and running cable blacktj27 Audio, CB & Ham Radios, GPS, & Electrical 27 08-20-2005 07:59 AM
