CB mounting spot - JeepForum.com
post #1 of 14 Old 11-15-2013, 07:50 PM Thread Starter
Bmel17
CB mounting spot
started installing my CB today. ran the coaxial cable and mounted the CB where I wanted. well I tried it in a few spots before I decided to go overhead. mounted it to my overhead gear setup. just wanted to see what you guys thought. pretty easy mount with the molle straps. just used zip ties.
I'll run the power and coax behind the windshield in the morning. then to test SWR
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #2 of 14 Old 11-16-2013, 01:04 AM
schmitkj
2010 JK Wrangler
Looks good, I drilled two small holes in the overhead for the mount. Did you have problems with SWR? Mine was around 1.8-2, I know it's OK but I know it should be lower. Using 18' Cobra Coax, Teraflex mount, and 3' Firestik II.
schmitkj is offline
post #3 of 14 Old 11-16-2013, 08:19 PM Thread Starter
Bmel17
I didn't wire up the power yet. Was trying to today, but had a ton of stuff to do and didn't get the chance so hopefully tomorrow I will.
I have 18' fire wire coax, 3' firefly and a mount that is similar to the teraflex mount I got off ebay.
08 HD Nightster
Bmel17 is offline
post #4 of 14 Old 11-17-2013, 02:02 PM
plumber1
Where did you guys get that overhead strapping it looks very cool
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #5 of 14 Old 11-17-2013, 03:10 PM Thread Starter
Bmel17
http://www.smittybilt.com/gear.htm
You can get it at a lot of online retailers like Quadratec. I think I got mine from 4wd. I like it because it adds a good amount of storage and is compatible with any other molle based pouches.
08 HD Nightster
Bmel17 is offline
post #6 of 14 Old 11-28-2013, 02:27 PM Thread Starter
Bmel17
Well I ended up wiring everything today which was quite easy (finally!). Drove down to a pretty open area and began adjusting my antenna. Ended up with 1.4-5 which by all accounts is pretty good~
08 HD Nightster
Bmel17 is offline
post #7 of 14 Old 11-30-2013, 04:39 AM
JPNinPA
I hope you mean 1.4 to 1.5 and not 1.4 to actually 5. Do not operate it if SWR is above 2.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #8 of 14 Old 11-30-2013, 11:05 AM Thread Starter
Bmel17
1.4 to 1.5 yes. sorry see where that could be confusing!
I am also getting a lot of feed back when I am moving. Can hear my engine. I ran the power/neg directly to the battery. any ideas?
08 HD Nightster
Bmel17 is offline
post #9 of 14 Old 12-01-2013, 10:19 AM
schmitkj
2010 JK Wrangler
Try running your neg. to the body, there are already grounding post on the passenger side next to the door strap. I had the same problem. My Cobra came with a NB/ANL which did the trick.
schmitkj is offline
post #10 of 14 Old 12-01-2013, 12:56 PM
plumber1
Does this come with a metal plate of some type to support it ?. I am installing a Hard Rock Cage, wondering if this will work with the HR cage.
plumber1 is offline
post #11 of 14 Old 12-01-2013, 01:52 PM Thread Starter
Bmel17
Yes, there is a metal plate the molle wrap goes around, no clue if it would fit that cage. Is there a br across where the stock one is?
08 HD Nightster
Bmel17 is offline
post #12 of 14 Old 12-01-2013, 02:33 PM
PhulesAu
Ground the radio.
PhulesAu is offline
post #13 of 14 Old 12-03-2013, 07:40 PM Thread Starter
Bmel17
worked like a charm. thanks! It def got rid of the feedback engine static.
Now it's still static-y, but I can hear people when I was closer to the interstate.
08 HD Nightster
Bmel17 is offline
post #14 of 14 Old 12-09-2013, 08:37 PM
JPNinPA
Some static is normal and natural. Read about noise on cobra website FAQ and on firestick tech documents.
JPNinPA is offline
