Quantcast CB mounting - pics - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > CB mounting - pics
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 10-14-2004, 07:36 AM   #16
Yeller'00sport
tin foil in the fuse holder
J/K man. Don't do that!! You could bump it up to a larger fuse, 5amps more should do it, since you now have a slightly larger load on the circuit
Yeller'00sport is offline   Reply With Quote
Old 10-14-2004, 09:32 AM   #17
Frozen_TJ
Originally Posted by MuddyAlaskaJeep
im havin probs with my cb. everytime i hook it up for some reason i fry the 10 amp fuse that goes to the dome light or I fry the 15 amp fuse to the cd player. my only clue as why this is happening is because its all on the same circuit. does anyone have any advice for me on how to fix it?
I do not know why it is blowing the fuses but, I would get a inline fuse for the + line of the CB and then run it to the battery. If the inline fuse keeps blowing then there is a problem with the CB..
[COLOR=Black][B][SIZE=3]Official JeepForum Secretary Of Foreign Relations[/SIZE][/B][/COLOR]
[I][B][FONT=Tahoma][COLOR=Blue]Alaska Jeep Member #1[/COLOR][/FONT][/B][/I]
[COLOR=DarkRed][FONT=comic sans ms][B][I]Red Jeep Member #233[/I][/B][/FONT][/COLOR]
[FONT=Comic Sans MS][B][URL=http://arctic.net/~erikm/off_road.html]4x4 In Alaska[/URL] [/B][/FONT]
Frozen_TJ is offline   Reply With Quote
Old 10-14-2004, 09:56 AM   #18
Frozen_TJ
Also it is cool to see someone from Alaska..
Old 10-19-2004, 03:44 PM   #19
Diehard
Diehard's Avatar
Do not connect the cb power wire thru the fuse block. Run a direct line to the battery with a fuse in line. You'll have to be sure to remember to shut off the radio, but this will give you a better power supply w/o any possible interference from any other electrical devices or engine static.
Diehard is offline   Reply With Quote
Old 10-20-2004, 04:24 PM   #20
shookwell
Even if you leave the CB on, it won't draw enough power to kill the battery even if you leave it for a few days.
shookwell is offline   Reply With Quote
Glock Forum
