CB Interference - JeepForum.com
post #1 of 13 Old 06-04-2012, 10:40 AM Thread Starter
pikegulley
2011 JK Wrangler
CB Interference
I have a Cobra 29 lx in my rig and when I turn my rugged ridge led lights on I get significant interference. I'm assuming it is due to the way the lights are wired. They are wired to the original fog light switch on the steering column. I have a friend who has 4 of these lights and has no issue with them and the cb (he has the same cb).
I have the cb power source ran directly to the battery and grounded to the frame on the passenger side in the cab.
Any opinions what is going on? It's not a huge ordeal right now since i don't have any night runs planned anytime soon.
Thanks!
2011 Black Rubicon "Rubi"
3.5" Rubicon Express Short Super Flex - 35" BFG KM2 - 4.88 gears - 1.5" Spidertrax wheel spacers - XRC front and rear bumpers - XRC 8 winch - Bushwacker Trail Armor - Bushwacker Flat Fenders
pikegulley is offline
post #2 of 13 Old 06-04-2012, 05:57 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use the original fog lamp switch to power a relay to run the lights. Your JEEP will thank you, and the CB probably will have less interference. Connect both the CB power and ground to the battery.
CJ7-Tim is offline
post #3 of 13 Old 06-04-2012, 07:07 PM Thread Starter
pikegulley
2011 JK Wrangler
Hmmm.....I had a shop install them while they were doing my gears. So I'm not sure how they exactly hooked it back up to the original switch. I Should have done it myself.
post #4 of 13 Old 06-04-2012, 07:11 PM
sjones26573
If they truly are LED, they probably draw so little current that it's not a concern. I'm curious as to how they wired them. However, adding a relay certainly can't hurt.
How did you run your Coax? It might be close to a hot wire, causing interference.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #5 of 13 Old 06-04-2012, 09:15 PM
streetglideok
2005 KJ Liberty
Try grounding the CB straight to the battery, and see what happens. That may be your issue.
streetglideok is offline
post #6 of 13 Old 06-04-2012, 10:22 PM
SnowdogMarc
X2^ what he said
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #7 of 13 Old 06-04-2012, 10:24 PM
ctak24
I know that the Cobra 29 LTD Classics have the ANL/NB on switch that you can turn on or off. Not too sure about the newer LX models. Make sure that the ANL/NB is on.
ctak24 is offline
post #8 of 13 Old 06-05-2012, 08:51 AM Thread Starter
pikegulley
2011 JK Wrangler
Those are turned on.
post #9 of 13 Old 06-05-2012, 08:52 AM Thread Starter
pikegulley
2011 JK Wrangler
Originally Posted by SnowdogMarc View Post
X2^ what he said
I'll give that a try and see what happens! Thanks!
post #10 of 13 Old 06-05-2012, 08:55 AM Thread Starter
pikegulley
2011 JK Wrangler
I think that the coax is fine. I have it running from the top of the roll cage down to the passenger side of the bed under the liner to the back. I wouldn't think that a wire running those front lights would be all the way back there.
post #11 of 13 Old 06-07-2012, 07:44 PM
JPNinPA
First determine if the noise is transmitted or power/ground. To do this turn on the CB and disconnect the antenna from the back. DO NOT TRANSMIT but note if the noise is gone. If the noise stopped it is transmitted noise. reconnect the antenna.
If the noise didn't stop and only happens when the lights are on, improve the power and ground connections to the lights. If it is still an issue measure your SWR with an external meter and post the results.
If it did not go away improve the power and ground of the radio. To do this first step is power and ground directly to the battery.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #12 of 13 Old 06-07-2012, 08:12 PM
ctak24
some people use CB coax to run the hot and ground wires to the battery using the center conductor as the hot lead and the outer braid as the negative lead. Supposedly this reduces interference through the radio. Never tried it though.
If the interference noise stops with the antenna unplugged, try grounding your tailpipe. I had major interference coming in through the antenna on my Camry and my radio tech told me to ground the tailpipe/exhaust because it can possibly act as an antenna radiating electrical noise coming from the engine.
ctak24 is offline
post #13 of 13 Old 06-07-2012, 10:15 PM
JPNinPA
He said it's only when he turns on his lights. But Yes the exhaust, fuel pump, even engine block/ ign system causes transmitted noise that is difficult to trace down. More likely on older vehicles.
As for the coax power is overkill and noise can come in through the ground just as easily as the power.
JPNinPA is offline
cb , interference , LED lights
CB Interference tfgnt16 Audio, CB & Ham Radios, GPS, & Electrical 5 06-12-2009 10:42 AM
CB interference??? pbjb25 Audio, CB & Ham Radios, GPS, & Electrical 20 01-23-2007 03:04 PM
interference jeeptraxx Audio, CB & Ham Radios, GPS, & Electrical 5 01-15-2007 08:25 AM
Help with CB interference pbjb25 Audio, CB & Ham Radios, GPS, & Electrical 1 12-22-2006 08:54 AM
Interference buddyfilek Audio, CB & Ham Radios, GPS, & Electrical 2 11-06-2006 03:56 PM
