CB Help (Cobra 29LTD)? - JeepForum.com
post #1 of 12 Old 05-17-2013, 08:21 PM Thread Starter
gemiller
2008 WK
So I'm completely stumped.
Firestik II 3' antenna
Saguaro 4x (Aspen Creek Offroad) - Antenna mount
Standard antenna bracket device
Cobra 29LTD
New 18' cable.
Device doesn't appear to transmit or receive. If I am parked right next to a vehicle transmitting on the same channel all I get is static but the swr gauge does swing.
The unit will not calibrate. Nothing happens when I put it in cal, key in the mic and hold it in and adjust the swr cal knob, the gauge does nothing. Even if I key in swr mode theres no response. The only response from the gauge is when another vehicle keys in but all I get is static.
I've taken the antenna bracket apart and ground down more metal to bare (beyond what I think is reasonable) and i've gotten no where.
I've tried a different antenna, cable, and mic. I'm not sure what i'm missing.
The unit never engages the "ant" light, but the tx/rx light is green unless keyed in when it goes to red. All switches appear to function correctly, but I still get no response.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #2 of 12 Old 05-17-2013, 11:10 PM
roadcrew
Where did the radio come from?
roadcrew is offline
post #3 of 12 Old 05-18-2013, 06:48 AM Thread Starter
gemiller
2008 WK
Bought it at a flying j truckstop supply store
gemiller is offline
post #4 of 12 Old 05-18-2013, 08:18 AM
roadcrew
I found that someone right next to me trying to communicate over the cb was useless. I could hear his key click and it was deffinatly getting my radio but I was getting no audio. We were too close. As soon as he turned the corner and we got more than say 100' away I could understand him again.
I would try to put that radio on someone's else's antenna that I knew worked. Most radio problems are faulty antenna installs. But you should have receive just by having anything in the antenna jack. Touch it with a screwdriver for example.
Don't transmit with out a proper antenna set up. It can and will fry the cb.
You do have the Squelch and Mic gain in the right direction right?
roadcrew is offline
post #5 of 12 Old 05-18-2013, 08:46 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are you sure all the buttons and knobs are correctly set as detailed in your owners manual ? The CB is not in PA Mode, correct ?
I would think that your new CB is defective if it will not either transmit or receive.
Even with no antenna plugged into the CB, it should clearly receive signals from a CB transmitting within 0 - 100 feet away. Even if the antenna is incorrectly installed, or incorreclty adjusted, the S/RF meter should swing to 4 when transmitting, and the SWR function should also swing the needle to the right.
CJ7-Tim is offline
post #6 of 12 Old 05-18-2013, 04:58 PM Thread Starter
gemiller
2008 WK
I've tried also open area no vehicles or anything around me and I still got nothing.
Best I can get is some crap static with all the dials maxed out and the nb/anl switch set to off with the antenna on. But still nothing seams to be receiving. And the SWR gauge doesn't move at all.
No matter what I do when I key the mic nothing happens other than if the nb/anl switch is off the static will drop but the swr gauge does nothing. The only time I got the swr gauge to move at all is when I had another vehicle key the channel I was on but all I got was static no audio.
gemiller is offline
post #7 of 12 Old 05-18-2013, 05:10 PM
roadcrew
When you the talk in the mike and the pwr/swr/cal is in the swr or cal position the needle will move. It has to be in the pwr position to move the needle when receiving.
Some times there is no one else out on the air. Do you have a friend with a radio for checks?
Edit: cuz I had my send/receive backwards.
roadcrew is offline
post #8 of 12 Old 05-18-2013, 07:49 PM Thread Starter
gemiller
2008 WK
According to the manual in cal mode the gauge should swing when keyed in and move with cal knob but it doesn't.
gemiller is offline
post #9 of 12 Old 05-18-2013, 08:00 PM
CJ7-Tim
CJ7-Tim's Avatar
According to the manual in cal mode the gauge should swing when keyed in and move with cal knob ......
Yes, you should be seeing that.
Your CB is probably defective. Contact Cobra directly for warranty service or exchange it for another one at the retailer.
CJ7-Tim is offline
post #10 of 12 Old 05-19-2013, 08:53 PM
JPNinPA
When you put it in cal mode press the PTT button ans set the output to cal by adjusting the SWR cal knob. Then switch it to SWR while still holding he PTT.
This will give yor a SWRReading. But do not rely on the radios SWR meter. They are usually good enough to get you out of the danger zone.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #11 of 12 Old 05-19-2013, 09:09 PM
CJATE
Double check grounds. If you have a buddy with the same unit, switch them. Plug his into your rig and vice versa. That will tell you if it's radio or connection.
Then send it back.
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #12 of 12 Old 05-20-2013, 08:09 PM Thread Starter
gemiller
2008 WK
FYI, Cobra determined its a bad radio based on over the phone troubleshooting, most likely a bad audio chip and they are replacing/repairing free of charge!
gemiller is offline
