CB engine noise over antenna?? - JeepForum.com
post #1 of 10 Old 05-18-2010, 06:48 PM Thread Starter
cidd
Installed new cb and I have bad engine noise comming over the antenna . I hooked the cb up to a jump box to make shure the power wirers were not the problem and its fine but as soone as you start the motor all hell breaks loose. I used the tail light type mount and have it grounded to the chassie with a nickel size area of bare metal and four bolts the only thing I can think of is the antenna itself might not be making good ground with the mount I may have to remove it and try cleaning some powder coat off and try agine. Anybody have any other ideas???
cidd is offline
post #2 of 10 Old 05-18-2010, 11:32 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Have you by chance swapped in any so-called "performance" spark plugs that are low resistance designs?
Jerry Bransford is offline
post #3 of 10 Old 05-19-2010, 04:51 AM Thread Starter
cidd
Put some E-3 plugs in about a week ago not shure if there low resistance or not
cidd is offline
post #4 of 10 Old 05-19-2010, 06:44 PM Thread Starter
cidd
Ok its seems to be the fuel pump so how do you get rid of it ?????
cidd is offline
post #5 of 10 Old 05-20-2010, 02:24 AM
Kovelan
Might try snap on style toroids AT the fuel pump itself. Use a few, they are cheap.
How the fuel pump grounded? Check this too.
KD5WDQ
Kovelan is offline
post #6 of 10 Old 05-20-2010, 04:17 PM Thread Starter
cidd
Ok guys if I hold the antenna the noise from the fuel pump goes away ???. Bought this set up from rightchannel sent them an e-mail and they tell me to put a noise filter on the cb I dont even have it powerd from the jeep yet its running off a jump box so I know the noise is comming from the fuel pump is squeels when you first turn the key to power then stops then when you start the jeep it comes back on and stays on that is untill you touch the antenna???
cidd is offline
post #7 of 10 Old 05-20-2010, 04:35 PM
Kovelan
Agree, it's the fuel pump. They are asking you to put on a "brute force" filter on the CB.
Nothing more that capacitors and inductors. Still believe toroids will work, or at least help.
And they are cheap. Also a cap across the power/gnd leads near the fuel pump might help
too. Toroids act like inductors when placed on the power/gnd wires. Try this first. Better
to try and fix the source than band-aid the radio. If you finally do use the "brute force" filter
do it at the pump.
KD5DWQ
Kovelan is offline
post #8 of 10 Old 05-20-2010, 06:49 PM
JeepinInFl
Just do this. Most filters that you can buy are junk. This will work for alternator noise, fuel pump noise, wiper noise etc.
RFI issues in the Ford Explorer
______
KJ4PUF
JeepinInFl is offline
post #9 of 10 Old 05-20-2010, 09:06 PM
Kovelan
Perfect picture of a toroid installation! They appear to be the toroids that radio shack sell too.
(thanks!) Try this first. Always do the easiest and cheapest first.
KD5WDQ
Kovelan is offline
post #10 of 10 Old 05-22-2010, 07:47 AM Thread Starter
cidd
I found a noise clipper from walcott it hooks in to the antenna cabel at the cb and cuts any noise comming from the antenna its $23.00 so I figured Id give it a try Ill let you know if it works.
cidd is offline
Antenna Noise CB Radio McKBrew Audio, CB & Ham Radios, GPS, & Electrical 3 11-13-2009 12:16 AM
my cb antenna topper fell off. does this matter? will it affect my antenna PJNovinskee27 Audio, CB & Ham Radios, GPS, & Electrical 3 11-03-2008 03:59 PM
Engine Noise Uncleboogie Audio, CB & Ham Radios, GPS, & Electrical 8 11-20-2006 07:13 PM
Run CB radio antenna through old cell phone antenna wire? FASTnSPEEDY Audio, CB & Ham Radios, GPS, & Electrical 8 09-26-2005 01:12 PM
Steel Spring for CB Antenna and Antenna cable question Bob J Audio, CB & Ham Radios, GPS, & Electrical 23 01-16-2003 07:02 PM
