CB coax and antenna question - Page 2 - JeepForum.com
post #16 of 20 Old 10-20-2013, 11:06 AM
biffgnar
biffgnar's Avatar
Originally Posted by Bmel17 View Post
so I understand if I wire the cb to the battery it have much cleaner sound than if I wire it to be switched on/off with the Jeep. How much difference does it make with the noise?
Too many variables that can be unique to your jeep to give a precise answer but it will be better. Never understood people's reluctance to do it. Its not hard.
biffgnar is offline
post #17 of 20 Old 10-20-2013, 06:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
First, don't worry that powering the CB directly from the battery means the CB won't shut off with the key. There will be many times on the trail where you'll want the ability to leave the CB on without also wanting the keys in the ignition or even in the On or ACC position. But as I said, don't worry about that since the CB could remain on for weeks if not months without killing the battery even if you never started the Jeep. CBs just don't draw enough power to worry about when not transmitting.
Noise-wise, there are just some power circuits that are electrically noisy... circuits that have the fuel pump or alternator on them being two such noisy circuits. Such circuits can introduce whining, buzzing, etc. into the CB's received and transmitted audio. Connecting directly to the battery will give you the cleanest/most noise-free power of any source of power on the Jeep. Not to mention the battery also looks like a big power filter that helps to filter out/absorb noise that may get introduced into various circuits it is exposed to.
Jerry Bransford is online now
post #18 of 20 Old 12-02-2013, 12:47 AM
plumber1
Jerry
What are your thoughts connecting the power supply to an S-POD and not directly to the battery ?
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #19 of 20 Old 12-02-2013, 09:12 AM
Jerry Bransford
Administrator
That would be fine if the SPOD is connected directly to the battery with the right (big enough) wire gauge.
post #20 of 20 Old 12-03-2013, 06:20 PM
plumber1
Yea the SPOD is connected to the battery, not sure of wire gauge I will have to check on that.
plumber1 is offline
