CB cable length - JeepForum.com
post #1 of 16 Old 10-22-2010, 03:59 AM Thread Starter
AlexGeorgakis
CB cable length
So I've got my CB and I've got my antenna. How do I know what cable length I need to use? I know there's a formula somewhere about this.
AlexGeorgakis is offline
post #2 of 16 Old 10-22-2010, 07:55 AM
mylt1
mylt1's Avatar
take a piece of rope, tie to your CB then run it along the same path you plan on running the coax to the antenna. when you get it where you want it and to the antenna mark the rope and measure how long it is.
mylt1 is offline
post #3 of 16 Old 10-22-2010, 09:21 AM Thread Starter
AlexGeorgakis
LOL, no, that's not the way it works. Cable length has to be specific for the frequency and antenna size you are using. Too long or too short and you won't have correct performance. I need a formula or some sort of calculator where I can plug in my antenna length and frequencies and I'll get the exact cable length I need. You don't cut off the excess cable length. You have to loop it in a figure 8 pattern.
post #4 of 16 Old 10-22-2010, 01:43 PM
Phreak480
thats made up garbage. the coax doesnt have to be a special length and you can coil it up just dont make it too tight or you migrate the center conductor towards the outer braid and change the impedence. you actually would want to avoid certain lengths. having your coax an exact wavelength or multiple of can cause issues.
what you do want to do is find someone local who knows about cb and or amateur radio and has an swr meter to help you tune your antenna.
Phreak480 is offline
post #5 of 16 Old 10-22-2010, 02:09 PM
97Formulaws-6
There's no special length cables for CB radio or formulas, etc.
The only adjustment that NEEDS to be made is a SWR adjustment for your antenna.
97Formulaws-6 is offline
post #6 of 16 Old 10-22-2010, 03:18 PM
mylt1
mylt1's Avatar
negative ghost rider, thats a bunch of malarkey. i have a general amateur license(working on extra) and can tell you, anyone who has told you that is full of it. keeping your run as short as possible means less line loss but in HF(which CB is) it really doesnt effect you that bad, plus im talking 100ft or longer runs,
mylt1 is offline
post #7 of 16 Old 10-22-2010, 06:39 PM
4wdjeepguy
Usually for a mobile set-up you want to keep it around 18' and you can dial in the rest via the antenna from there. You shouldn't have that much if any excess cable if your running it from your radio in the front to the antenna in the rear.
And yes, I'm running 75' of cable on my base, but also, most base antenna's are set-up to self-adjust their SWR for whatever length of cable you are running. Setting up a base if diff from mobile
4wdjeepguy is offline
post #8 of 16 Old 10-22-2010, 08:11 PM
SnowdogMarc
Really?...I only needed 9' when it was in the center console and 12' when I moved it to the overhead console I built.
Use whatever length of cable you need to get from point A to point B and leave about 6-8 inches of extra for repairing connectors down the road.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #9 of 16 Old 10-22-2010, 08:17 PM
mylt1
mylt1's Avatar
dont know who told you that but they lied to you to. antennas do NOT "self adjust". they still need to be either trimmed to get a good SWR or you use an antenna tuner or are preset from the factory. even if they are preset they still need to be check once installed just to make sure its right.
mylt1 is offline
post #10 of 16 Old 10-22-2010, 09:10 PM
4wdjeepguy
didn't know imax 2000s and antron 99s need to be trimmed. interesting...
post #11 of 16 Old 10-23-2010, 07:54 AM
Phreak480
any antenna would need to be tuned. theres plenty of "CB" antennas that just dont have any actual tunability built in though. and the 18" of coax thing is a bunch of junk. I've been a licensed amateur radio operator for a while now and have done countless antenna installs for various frequencies. also not all antennas are tuned by trimming some have other ways of being adjusted. the antron has rings that adjust the tuning of it for lowering your swr for example.
post #12 of 16 Old 10-23-2010, 09:58 AM Thread Starter
AlexGeorgakis
Hey guys, thanks for the input. This is all new to me. I've been told that the coax is essentially an extension of the antenna which is why it has to have the correct length in order to operate at it's optimal level. My CB has inbuilt swr but even after tuning I still had worse performance than others did with "correct" length coax. And it makes sense that the coax is an extension of the antenna since it's just a continuation of a conductor. Perhaps my problems arose from the fact that my CB wasn't connected directly to the battery resulting in more noise. That's all fixed now so I'll test it tomorrow.
post #13 of 16 Old 10-23-2010, 02:10 PM
mylt1
mylt1's Avatar
dont depend on built in SWR meters. get a real meter and test your antenna.
mylt1 is offline
post #14 of 16 Old 10-23-2010, 02:14 PM
mylt1
mylt1's Avatar
those are pre=tuned but should still be checked with a meter.
mylt1 is offline
post #15 of 16 Old 10-23-2010, 04:07 PM
JChors
Coiling can create an "RF choke". It's better to loop excess cable in a 'figure 8' as the previous poster said...
JChors is offline
SWR cable length Speed94 Audio, CB & Ham Radios, GPS, & Electrical 2 09-17-2010 10:06 AM
RB1 and CD changer cable or Song/Artist cable? thebq Audio, CB & Ham Radios, GPS, & Electrical 5 09-06-2007 12:43 PM
What length CB antenna RockyMTN05 Audio, CB & Ham Radios, GPS, & Electrical 9 09-26-2005 04:53 PM
cv length after lift yellow04 Tires & Wheels 3 09-14-2005 06:26 PM
cb mounting spots and cable length kennyb Audio, CB & Ham Radios, GPS, & Electrical 5 09-20-2004 04:04 PM
