cb antenna probs - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > cb antenna probs
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 02-14-2008, 09:25 AM   #1
cabbotts
cb antenna probs
I installed a cb a month ago, it was working fine after it was tuned. This is the second cb i've installed in my life so i'm somewhat familiar, but not a genius when it comes to them. Anyway, i started to not get any static when squelched. I thought it might be the ground. I went back and turned the antenna on my gutter mount and got static back. it must have been a connection issue I thought. Then i went back and loaded it by pressing the mic button. I lost all static again. Went and did the same thing, and lost it again over and over.
I tore the mount apart and put it back together. It worked and kept the signal after i loaded the mic. Seems to be working just fine for a day.
For future reference, what was wrong? Just a bad connection to ground or antenna?
SWR was fine.
Chris
cabbotts is offline   Reply With Quote
Unread 02-15-2008, 03:54 PM   #2
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I am going out on a limb here....
If you are using a 3/8 stud mount, they are common to get rust and axidation build up,
thus decreasing the performance.
The stud needs to be cleaned, ( the threads) to ensure good contact with the antenna.
Same thing with the SO 239 / pl259 cox connectors.
On exposed connectors I ussually wrap them up first with electrical tape, and then after
with really gooey sealing stuff. ( just so when IU want to take it out, I slice through to the
layer of electrical tape and take it all out without leaving a gooey mess on the cable.)
Check all your grounds fpr tightness.
SpeedyCat3 is offline   Reply With Quote
Unread 02-17-2008, 08:46 AM   #3
cabbotts
Tried that. It's a pretty new setup and I didn't think that could be it. I cleaned the threads out really good and it's back to normal. Thanks. I'm just amazed at how quick that corrosion could happen.
THanks again,
Chris
Unread 02-17-2008, 12:27 PM   #4
muddmonky
i have my squelch turned all the way down (counter clockwise) and dont have any statick either is that bad??????
both the negitive and positive are hooked straight to the battery
muddmonky is offline   Reply With Quote
Unread 02-17-2008, 01:29 PM   #5
muddmonky
what does it mean if you dont have static. good bad what
all my conections are clean. it was bare wire clamped to the post.
Unread 02-17-2008, 03:06 PM   #6
muddmonky
never mind i fixed it my nb/anl was switched on as sune as i turned it off i got the statick and reception i had when i first hooked it up.
