CB Antenna mounts - JeepForum.com
post #1 of 7 Old 09-25-2002, 04:57 PM Thread Starter
firefighter570
CB Antenna mounts
I need some help in locating a CD antenna mount for a '99 TJ, I saw one that attached to the bolt to the rear gate and required no drilling. If anyone knows of a mounting bracket or anything that i could use, without drilling holes, I could really use the help.... Thanks
firefighter570 is offline
post #2 of 7 Old 09-25-2002, 05:06 PM
ageofzeppelin
Check out www.valcoelectronics.com
1993 XJ Sport
4.0L, HO
5-speed Manual
235's and a few other little things.
ageofzeppelin is offline
post #3 of 7 Old 09-26-2002, 07:31 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
Try a Jeep specific parts supplier for the mount, they tend to have the most common.
I like Quadratech or 4WD Harware.
There is a mount that attaches to the right rear of the Jeep as part of the tire stop. Also, there is a mount that attaches to the tire mount high in the middle.
Both should work, just get an antenna long enough.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #4 of 7 Old 09-26-2002, 11:01 AM
RideRed04
RideRed04's Avatar
I could be wrong, but I dont think that tj's have the tire stop.
2000 WJ Limited 4.7 QD
RideRed04 is offline
post #5 of 7 Old 09-26-2002, 05:45 PM
Scrambler82
1982 CJ8
Cool
As I said I am new to Jeeps so you are proably right.
Look at what is available form the suppliers in my last post and maybe there willbe something you can use.
Scrambler82
post #6 of 7 Old 09-26-2002, 10:25 PM
mpadfield
Try the TeraFlex mount. It attaches behind the tail light. You can get one for either the left or right. They recommend, and so do I, that you drill one hole through the body to help with stress. I picked one up, and have not had any problems with it yet.
"Someday I'll have the Jeep I always wanted..."
mpadfield is offline
post #7 of 7 Old 09-28-2002, 08:43 PM Thread Starter
firefighter570
thanx guys, i found a mount on
http://www.1stopelectronics.com/
i bought a basic adapter, and when i get it i have to make a couple of minor modifications(drilling a hole throught the mount to attach it to a screw) hope it works out well.... Thanx again for your help
Amateur and CB antenna mounts on an LJ clb251 Audio, CB & Ham Radios, GPS, & Electrical 8 12-01-2009 02:13 PM
TJ/LJ CB Antenna Mounts? .Jch. Audio, CB & Ham Radios, GPS, & Electrical 1 11-03-2007 09:53 PM
Antenna mounts SGT Superman Audio, CB & Ham Radios, GPS, & Electrical 7 08-20-2005 07:11 AM
TJ CB Bumper Antenna Mounts? nikki Audio, CB & Ham Radios, GPS, & Electrical 6 02-03-2005 09:42 AM
Teraflex antenna mounts Gunner11 Audio, CB & Ham Radios, GPS, & Electrical 0 01-04-2005 08:32 PM
