CB Antenna mount location for 2010 JK - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > CB Antenna mount location for 2010 JK
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 11-21-2010, 09:03 PM   #1
herculz
2010 JK Wrangler
Just installed a 2' firestick on the rear taillight arm with an L shape bracket that comes with most kits, had this installed on my TJ with selftapping screws on rear quarter panel, i never had might antenna short ID light up until now, i can talk with other cb'rs but its bugging me where this short could be.
Are there any brackets out there to successfully mount an antenna with out drilling into the body?
herculz is offline   Reply With Quote
Unread 11-22-2010, 03:35 PM   #2
2ksaharawhite
ARIZONA ROCKY ROAD ANTENNA MOUNTS FOR JEEP WRANGLER, UNLIMITED AND LIBERTY
Just bought myself a JK tailgate/spare-tire mount there.. About $35 with shipping (great deal). I am just waiting for it in the mail and I'll be all hooked up. No drilling required, it bolts right onto the spare tire rack with factory bolts, super easy install. Rick, the owner, told me it would even support a 102" whip with a 6" spring; so it can handle quite a load (good for large HAM antennas).
Keep in mind the tailgate isn't the best ground on the Jeep; you may want to run a ground strap from the back of the tailgate (inside the Jeep) to the tub. Make sure you remove the paint where you drill the hole so you get the best ground possible.
-Jonathan
Current Jeep: 2007 JK Rubicon 6spd - Red Rock
Previous Jeep: 2000 TJ Sahara auto - Stone White
Currently restoring: 1947 CJ-2A, fair condition.
Sitting around: 1965 CJ-5A (chassis, engine, tranny, and wheels).
2ksaharawhite is offline   Reply With Quote
Unread 11-22-2010, 10:37 PM   #3
herculz
2010 JK Wrangler
Think i will try to fab that up, i used self tapping screws and ran some wire to ground antenna mount, will take your advice on grounding straps from tailgate to tub, radio works now pretty good can run better after a good ground.
Unread 11-24-2010, 05:35 PM   #4
monkers
2010 JK Wrangler
post some pics of your mount when done please, I have a 2010 2dr Rubicon and would like to put a CB in it but know nothing about it.....so, looking for suggestions on where to mount the CB and ant, gonna go with the Uniden kit from Right Channel I think, I can fab my own mounts also out of stainless, just not sure where the best spot is, or the best radio spot................thanks
monkers is offline   Reply With Quote
Unread 11-24-2010, 07:43 PM   #5
mrsig
This is the mount I made! Used the 2 tail gate bolts and cut a slit in the plastic trim!
JK 4 Door Auto, 35" MTKs, River Raider Snorkel, Dana 44 Axles w/410 Gears, Front & Rear E Lockers , TF 2.5" Suspension Lift, BDS 2" BL, 10,000 lbs Front or Rear Winch, To see mods & my Jeep in Action @ http://www.aaof.us/jeep.htm CEO of Black Sheep 4x4s http://www.blacksheep4x4s.org,
https://www.facebook.com/blacksheep4x4sorg
Member of CCJ, White Jeep Club Member #137.
mrsig is offline   Reply With Quote
Unread 11-24-2010, 07:46 PM   #6
BAMAJK
2009 JK Wrangler
Cooltech makes a pretty cool set up also. Cool Tech LLC. JK Ultamount CB Antenna System
BLUE JEEP #237
BAMAJK is offline   Reply With Quote
Unread 11-25-2010, 01:11 AM   #7
hookuspookus
thats because your antenna is too close to the body of the jeep its not a short its high SWR's try a 6 foot wilson silver load and mount a ball on the side of the jeep ! firestick , not really a good antenna
hookuspookus is offline   Reply With Quote
Unread 11-25-2010, 01:14 AM   #8
hookuspookus
best spot , use a stainless steel ball mount , mount on the rear quarter panel and use a GOOD antenna like a wilson silver load
Unread 12-04-2010, 10:00 PM   #9
goofball
2011 JK Wrangler
my antenna mount.....works pretty good.. making one for the other side...
I want 2 mounts.. one for HF and one for CB or 2M.
took the cable up next to the roll bar on the passenger side down through the front window molding, down under the passenger side over to the dash down the console to the center. Radio might go under the seat.. right now using an HT. Jeep is so easy to route wires in.... I hope the power to inside is as easy... firewalls are always fun.. Not.
I posted this just cause I like seeing what others did... good ideas are gained..
build pic
goofball is offline   Reply With Quote
Unread 02-19-2011, 09:30 AM   #10
walkingstranger
CB Antenna Mount by Teraflex from 4Wheel Drive http://www.4wd.com/productdetails.aspx?partID=41223
They sit behind the brake light and don't require drilling. I did add a screw to mine, just for stability.
By null at 2011-02-19
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)=@==)_)
walkingstranger is offline   Reply With Quote
