CB Antenna Location - JeepForum.com
post #1 of 43 Old 08-14-2006, 12:30 AM Thread Starter
juggle9
CB Antenna Location
Just installed my CB today before I came to work. Did not have time to attach my antenna perm. to my spare tire mount. Right now it is just bungie corded to my roll bar that runs vertical in the back. Fits nice under the tops and I can raise it when the tops are down and easy to stow if I leave my Jeep unattended. Got a ground wire to the antenna already. Not sure what kind of reception it gets, but I am thinking about leaving it there. What say ye?
juggle9 is offline
post #2 of 43 Old 08-14-2006, 12:39 AM
farinspace
i started by drilling an antenna mount on my stock spare tire carrier ... i think bought a teraflex mount for like 30 which worked out much better, ill post some pics if i can, i still need to ground everything. im using a firestick 2 antenna, and it works good for me .
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline
post #3 of 43 Old 08-14-2006, 04:36 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
i'm gonna put mine on the rear bumper. between the cb and ham, i'll just have one on each side
Grewe02 is offline
post #4 of 43 Old 08-14-2006, 05:04 AM
175MM BULLDOG
175MM BULLDOG's Avatar
An inverted "L" bracket on the side of the spare tire carrier is good. I started out with the L bracket on the bumper, and reception was bad at best.
Gun control: "The ability to hit your target"
175MM BULLDOG is offline
post #5 of 43 Old 08-14-2006, 05:53 AM
keoki04
keoki04's Avatar
I put mine on the rear bumper. It's a small picture, but it is on the passenger side. You can see the spring which is a quick disconnect. It works great!!
Name:  Rear Light Install Web.JPG
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
Clicky
Clicky
keoki04 is offline
post #6 of 43 Old 08-14-2006, 07:19 AM
BillR
BillR's Avatar
Mine's on an "L" bracket that attaches under the tail light. (between the tail light and the body) With a 4' Firestick, I get good reception.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #7 of 43 Old 08-14-2006, 07:24 AM
itsnotaheep
i got the teraflex mount. MY firestik will snap before that mount will move. I have a 3 foot antenna good reception real clear. and a cheapy midland cb. I dont run a spring because it go irritating on the highway. If i did it again i'd get a midland k-40 cus its real flexible and comparable to a firestik. Hope that helps.
3 inch teraflex lift
2 inch body lift
arb bull bar
9.5ti winch
35 mt/rs
locked cocked and loaded
itsnotaheep is offline
post #8 of 43 Old 08-14-2006, 07:54 AM
bryans98tj
I mounted mine to the spare carrier. $9 bracket from Radio shack. I can get a pic when I get home later.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #9 of 43 Old 08-14-2006, 08:29 AM
Fritz R.
I've tried about three different locations from the bumper, tire carrier, and finally just above the drivers side tail light. The last location definately works the best. I wasn't thrilled about drilling holes in the body, but I did want the CB to work right too. On the bumper and tire carrier I got a horrible squealing noise from the fuel pump. It drove me nuts. Locating the antenna to above the drivers side tail light got rid of 95% of the fuel pump noise. And my reception and transmit seem to work great. The SWR was much easier to tune too. I'm using a 3 ft Firestick, and a Cobra wx75.
Fritz
'97 TJ, 4.0L, AW-4, Flipped D300/4:1, ARB's, D44, Swayloc, RK LA, PC coils, Rancho 9000's, 33x12.5 Trxus, etc.
Fritz R. is offline
post #10 of 43 Old 08-14-2006, 08:53 AM
03jeeper78
03jeeper78's Avatar
I've read that the tip of the antenna should be above the level of your top. My setup is at the end of my sig, and it doesn't have the best range, but works awesome on trail rides.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #11 of 43 Old 08-14-2006, 09:04 AM
dragginwagon406
This works great even though I have not been able to get the SWR below 2.4 I used co-phasing cable and twin 102" whips mounted on HD springs.
In the woods, the mounts are very flexible and have not caused any problems.
I like the look too :shrugs shoulders: Like a mini big rig
dragginwagon406 is offline
post #12 of 43 Old 08-14-2006, 09:46 AM
175MM BULLDOG
Attachment 19421
Believe me, you will see a world of difference if you install it on your tail light, or tire carrier.
post #13 of 43 Old 08-14-2006, 09:47 AM
Jon2109
Ya, I found the best place for it was on the left side on the back bumper. Out of the way and easy to install. I woudln't worry about anyone stealing it, most people don't know what it is/how to work to even have an interest in stealing it.
Jon2109 is offline
post #14 of 43 Old 08-14-2006, 10:22 AM
CNY
Caught ridin' dirty
For an antenna, I mounted a K40 3' fiberglass to the side of the spare tire carrier. I use a quick disconnect, but the 3 footer barely peeks over the roof, so I don't have to disconnect often.
I run the antenna cable and ground wire into the tub, by just going over the top of the hatch.
CNY is offline
post #15 of 43 Old 08-14-2006, 10:59 AM
jcd
jcd's Avatar
Another vote for the Terraflex mount - rock solid and a great location.
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline
antenna location? tjmaniac Audio, CB & Ham Radios, GPS, & Electrical 2 01-05-2009 09:02 AM
CB antenna location claytonandson General Jeep & Off-Road Equipment 18 01-25-2008 06:10 PM
CB antenna mount Location Mondo Audio, CB & Ham Radios, GPS, & Electrical 9 03-10-2007 08:56 PM
HAM antenna... mounting location? Grewe02 Audio, CB & Ham Radios, GPS, & Electrical 13 02-15-2007 02:40 PM
CB antenna location firefitr26 Audio, CB & Ham Radios, GPS, & Electrical 2 06-13-2004 05:06 PM
