CB Antenna help needed. - Page 2 - JeepForum.com
post #16 of 28 Old 02-05-2014, 07:51 PM
wheelnmac
5 1/2 foot Wilson tuneable antennae
wheelnmac is offline
post #17 of 28 Old 02-05-2014, 09:03 PM
JPNinPA
Originally Posted by prerunner1982 View Post
The hood, like the tailgate has a poor ground connection to the body/tub.
My tj has a factory hood ground strap from the ground below the cowl. So the hood should be a good ground.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #18 of 28 Old 02-06-2014, 06:56 AM
Ross
Yep, same with roof racks, fenders, doors, tail gates, tire racks even bumpers. Anything that attaches to body MAY provide a less than ideal RF ground point.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #19 of 28 Old 02-06-2014, 06:57 AM
Ross
I have never really noticed one, but have never really checked. I have an 01 and it maybe different.
Ross is offline
post #20 of 28 Old 02-06-2014, 01:47 PM
prerunner1982
1993 XJ Cherokee
seen them with and without... but you are correct it should have been a decent ground plane.
Jon
1993 XJ Sport 2 door 4x4
1997 XJ Sport 4 door 4x2- RIP 6/6/16
2000 XJ Sport 4 door 4x2
prerunner1982 is offline
post #21 of 28 Old 02-11-2014, 07:19 PM Thread Starter
doclouie
Okay so I received my 3' firestik antenna and tuned it. I get a SWR of 2.5 on channel 1 & channel 40 with a SWR of 1.4 on channel 20. I am going to stick with this setup and call it good because I cannot fit a 4' firestik in my garage.
2000 Sahara, 3.5" Rubicon Express Lift, 1" spring spacer & 1" Body Lift, 35" BFG Mud tires, Front & Rear ARB, Rancho 9000 shocks, UCF Ultra High Belly Up Skid.
doclouie is offline
post #22 of 28 Old 02-11-2014, 07:34 PM
wheelnmac
You're still way to high. Let's investigate your cable. Have you tried a better quality cable? Have you checked all of your connections?
post #23 of 28 Old 02-11-2014, 07:40 PM
wheelnmac
What does the meter say on channel 40
post #24 of 28 Old 02-11-2014, 07:55 PM Thread Starter
doclouie
Originally Posted by wheelnmac
what does the meter say on channel 40
2.5
doclouie is offline
post #25 of 28 Old 02-11-2014, 07:58 PM
JPNinPA
2.5
Good luck. They are low enough to work. Any issues will show eventually.
JPNinPA is offline
post #26 of 28 Old 02-11-2014, 07:59 PM Thread Starter
doclouie
I have tried a better quality cable with no difference at all. I also checked all the connections and they all check out. I am an engineer so the testing is pretty straight forward for me. The only thing I can think is the length of the antenna, but 3' is as tall as I can go.
doclouie is offline
post #27 of 28 Old 02-11-2014, 09:44 PM
wheelnmac
http://www.wilsonantenna.com/product...itswhips-tips/
Wilson has several tuneable antennas that will fit your rig. Here is another idea, put a SWR meter in line between the radio and antenna and tune it that way.
post #28 of 28 Old 02-11-2014, 10:04 PM Thread Starter
doclouie
http://www.wilsonantenna.com/product...itswhips-tips/ Wilson has several tuneable antennas that will fit your rig. Here is another idea, put a SWR meter in line between the radio and antenna and tune it that way.
When I tuned it I put the SWR between the antenna and radio. I think I will just call it good as it is below 3.0 and will not damage the radio.
doclouie is offline
