cb antenna for fiberglass body? - JeepForum.com
post #1 of 10 Old 10-28-2006, 04:06 PM Thread Starter
shmoken875
shmoken875's Avatar
what are the options for putting a cb antenna on a fiberglass body because I know you need a decent ground. my buddy's girlfried is trying to get him one.
44:4.56, Alloy USA chomos, Yukon Superjoints, Lockrite / 9":4.56, Detroit
Caged/Skided xj on 37s with some other goodies
-Sinking Creek 4wd Association Blacksburg, VA
My 44 Build:
shmoken875 is offline
post #2 of 10 Old 10-28-2006, 08:11 PM
Rick_W
Fire Stik No Ground-Plane Antenna Kit
3-way mount or molded side mount
http://www.firestik.com/CatalogFrame.htm
Rick_W is offline
post #3 of 10 Old 10-28-2006, 08:19 PM
CNY
Caught ridin' dirty
Head on down to the local marina. They know a thing or two about mounting antennas without a ground plane.
Oh, and as Rick points out... The problem is not lack of ground (you can always ground to metal or the battery). The problem is lack of ground plane.
http://en.wikipedia.org/wiki/Ground_plane
CNY is offline
post #4 of 10 Old 10-28-2006, 09:13 PM Thread Starter
shmoken875
shmoken875's Avatar
thanks fellas
My 44 Build:
post #5 of 10 Old 10-29-2006, 09:27 AM
Ryuu600
this is the reason truckers run co-phased antenna's. The truck body's are fiberglass.
The Jeep also has a less than optimal ground plane but it gets the job done. I'm gonna co-phase 2 102" whips just for fun.
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
'06 TJ X Blue w/dark khaki top, 4.0L, 6 spd, 3.73, 30x9.5R15 Wrangler GS-As mounted on Ravine wheels, Soft-top w/half doors, 4 100w ProComp Offroad lights(2 bumper, 2 windshied), Cobra 29 LTD w/4' Firestik, Custom rear storage box.
Ryuu600 is offline
post #6 of 10 Old 10-29-2006, 11:44 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If the antenna is mounted to the bumper, you can go with a conventional antenna. If you really want to mount it to the fiberglass body, you must use a no-groundplane mount. But be aware that no-groundplane antennas do not perform nearly as well as a conventionally mounted antenna does. A regular antenna that is mounted to the frame, bumper, or steel body makes use of the tub/chassis as part of the antenna which is called the groundplane. It's like doubling the size of the antenna. A non-groundplane antenna has to make do without all that so it doesn't perform nearly as well.
Jerry Bransford is online now
post #7 of 10 Old 10-29-2006, 12:10 PM
KA5IVR
KA5IVR's Avatar
What "Einstein" told you this? If you believe it, I have some Ocean Front property for sale in AZ. I think you mean counterpoise antennas and that is a different monster.
Trucker's run Co-Phased antennas because of the radiation patten, not fiberglass, and Jeeps are not wide enough to co-phase antennas on 11 meters unless you do it front and back.
KA5IVR ~ 2006 Rubicon, Flame Red, Hanson Bumpers, Warn 9.5ti, and a lot of other $$$ sucking items...
KA5IVR is offline
post #8 of 10 Old 10-29-2006, 09:11 PM
Ryuu600
well thank you KA5IVR. I appreciate you correcting me on that. Do me a favor though and try to be a little less abrasive about it next time.
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
Ryuu600 is offline
post #9 of 10 Old 10-30-2006, 06:05 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Mounting the Antenna in the rear of the vehicle to the bumper or on the tire carrier is the best over-all location.
You won't gain anything by mounting on the top of the vehicle except radiation pattern. If you get the antenna to work correctly on the top of the fiberglass top you will have a radiation pattern that is more circular, on the rear of the vehicle the pattern toward the front of the vehicle, which is usually where you want it.
Save a lot of headaches and mount it on the tire carrier...
Luck,
p.s. Ditto - KA5IVR
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #10 of 10 Old 10-30-2006, 10:09 AM
Scrambler82
1982 CJ8
To add a little more... I have been thinking about this problem.
What would happen if a false ground was setup on the inside of teh fiberglass top?
Setup a counter poise (fake ground) by running a number of copper wires in different direction on the inside of the top. Would this be adequate to create a ground close to teh antenna ?
It has been done on HF setups where wire are run along the earth to create a grouns to bounce the signal off of.
Just thinking out loud.
Scrambler82
How to re-paint a fiberglass body ? syphonation General Jeep & Off-Road Equipment 4 04-01-2009 10:21 AM
Fiberglass antenna replaced with whip noodlestsc Audio, CB & Ham Radios, GPS, & Electrical 3 06-10-2007 12:13 PM
Antenna Grounding in Fiberglass Scrambler82 Audio, CB & Ham Radios, GPS, & Electrical 4 11-02-2006 10:20 AM
Fiberglass body lift? strvger Tires & Wheels 2 09-27-2005 10:39 PM
Antenna mount on fiberglass river rat Audio, CB & Ham Radios, GPS, & Electrical 2 01-24-2005 08:55 AM
