CB: Another High SWR Thread - Page 2 - JeepForum.com
post #16 of 19 Old 06-10-2013, 04:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
11
Originally Posted by 686keydragon View Post
My assumption is that the 3' firestick just didn't get high enough above the roll bar. Now my only issue is that the 4' antenna is too tall for my garage.
Could be but my Firestick FS-2 2' antenna, mounted at just above tail light height, has a 1.3 SWR and it doesn't make it above the rollbar at all. My antenna is 2' so the TJ can fit into the garage.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #17 of 19 Old 06-10-2013, 06:20 PM Thread Starter
686keydragon
Originally Posted by JPNinPA
Roll bar should not have been a problem unless it was 2-3 in away. Sounds like the antenna is open as the adjustments did nothing for you initially.
Anyway glad to hear you got it fixed.
Originally Posted by Jerry Bransford
11Could be but my Firestick FS-2 2' antenna, mounted at just above tail light height, has a 1.3 SWR and it doesn't make it above the rollbar at all. My antenna is 2' so the TJ can fit into the garage.
Well that's good news. I'll have to try another 3' antenna to see if it was just DOA (still a few years away from needing a 2' antenna).
2002 TJ, 2.5L, 4" lift, 33" dunlop mud rovers, xrc8 winch, aussie locked d30, a-z fabrication ww2ww sliders, mounted mv-50 compressor, SirGcal sub box
686keydragon is offline
post #18 of 19 Old 06-18-2013, 08:03 PM
WJ02FNG
http://www.wilsonantenna.com/faq.php Pay attention to #8 - the other FAQs should be able to help out as well.
WJ02FNG is offline
post #19 of 19 Old 06-18-2013, 09:34 PM Thread Starter
686keydragon
See a few posts up; this was resolved by changing the antenna. Thank you for the thoughts though.
