can you use one channel of a two channel amp safely? - JeepForum.com
post #1 of 6 Old 03-15-2003, 04:56 PM Thread Starter
idcx3
I was wondering if it is safe to use just one channel of a two channel amp? this is just temporary until i can get my other sub installed
idcx3 is offline
post #2 of 6 Old 03-15-2003, 06:06 PM
MAjeep87
MAjeep87's Avatar
wait kind of amp is it. you could always bridge it if the amp is able too. Yes you can only run one channel of the amp as long as it is able to take the ohms you are putting to it. example your amp is 2ohm stable and u try running it at 1ohm.
MAjeep87 is offline
post #3 of 6 Old 03-16-2003, 12:54 PM Thread Starter
idcx3
the amp is a fasgate 1000a2...2 ohm stable..i currently have it bridged and its way to powerfull for the sub...but if it is just drawing off of the left or right channel alone it would be pulling RMS power...i just didnt know if this would be safe on the amp
idcx3 is offline
post #4 of 6 Old 03-16-2003, 06:49 PM
prophesized
just turn the gain down all the way instead
prophesized is offline
post #5 of 6 Old 03-17-2003, 02:39 PM
Bucket110
Bucket110's Avatar
yes that is completely safe...cause it would think it is powering two subs but is really only powering one...its fine.
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
NEJEEPZ
Bucket110 is offline
post #6 of 6 Old 03-17-2003, 06:17 PM
CJ Fanatic
CJ Fanatic's Avatar
It is not recommended to run only one channel of a two channel amp. The reson being, the outoput transistors of most amps require a balanced load across both channels. I too would suggest turning the gain down to a level that works for your application.
A closed mouth gains no foot.
1977 CJ5, '75 258, Motorcraft 2150 carb, HEI dizzy, BDS 2.5" suspension, 3/4" Daystar Rock Krusher Greasable shackles, M.O.R.E. steering brace, Flaming River steering shaft, Tie rod flip, Yukon AMC20 axle kit, 1.5" Trail Sport wheel spacers, 15x10" Black Cragar soft 8s w/ 33" Yokohama Geolander MTs, Goodridge SS brake lines, Classic Tube stainless hard lines, YJ power brake with front disc upgrade (had 4 wheel drums)
CJ Fanatic is offline
4 Channel Amp Dexter01 Audio, CB & Ham Radios, GPS, & Electrical 8 10-13-2009 10:18 AM
Got a new 4 channel amp!! bobthetj03 Audio, CB & Ham Radios, GPS, & Electrical 11 04-18-2007 08:21 PM
What Channel? Snowman01TJ Audio, CB & Ham Radios, GPS, & Electrical 5 01-06-2004 06:30 AM
CB channel? coolhand General Jeep & Off-Road Equipment 9 09-10-2003 05:51 AM
Help quick! 4 channel > 2 channel? ZmOz Audio, CB & Ham Radios, GPS, & Electrical 2 07-07-2003 07:34 PM
