Can I cut my fog light wire? - JeepForum.com
post #1 of 6 Old 05-08-2013, 04:09 PM Thread Starter
TJJeepJosh
I bought my jeep without fog lights but it was factory wired to have them so I went ahead and bought some KC replacement fog lights.
But, with the way my bumper is set up to mount the lights, the factory wire will not reach them.
Is it ok to cut the wire and just add some more wire in between? Or do I have to buy an extension like this http://www.teraflex.biz/tj-wrangler-...sion-wire.html
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 6 Old 05-08-2013, 05:16 PM
MyKeyB
Yeah, splice them in, just make sure you use the same gauge or heavier wire. You can use those extensions if you want it to look clean and be simple but using different wire is no problem. Your gonna need a relay and a switch too.
Rust never sleeps...
MyKeyB is offline
post #3 of 6 Old 05-09-2013, 06:03 AM Thread Starter
TJJeepJosh
Splicing them seems like a lot better idea compared to spending an extra $40.
post #4 of 6 Old 05-09-2013, 09:38 AM
Ross
I rewired my KCs. I had a problem with switch on the steering column. My fog lights would randomly turn on leaving me with a dead battery.
If the stock fog light wire is as thick as the KC lights I would thing you would be fine but the thing that concerns me is the stock fog lights were only 55 watts, you KC light are probably considerably more than that.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is online now
post #5 of 6 Old 05-09-2013, 04:26 PM Thread Starter
TJJeepJosh
I bought the direct replacement fog lights. Not sure on how many watts they are though. I'm guessing 55-100w?
http://www.kchilites.com/store/produ...x-%231134.html
post #6 of 6 Old 05-09-2013, 06:57 PM
GilaMtnJeep
GilaMtnJeep's Avatar
They have the same electrical requirements and will be fine connected to the stock wiring. They were made specifically as replacements for stock fogs.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
factory option , fog lights , wire
