buzzing in speakers - help? - JeepForum.com
post #1 of 7 Old 05-05-2013, 08:24 PM Thread Starter
cbass68
Getting a buzzing/crackling noise through through the stereo speakers - radio only. Replaced the stereo ground with good frame contact. Replaced the antenna extension cord with new. Only happens with engine running. Anybody run into this and figure the fix? 97 wrangler
Thanks for any help!
1980 CJ-7 - sold
1997 TJ - sold
1991 YJ -project for sons' first vehicle
cbass68 is offline
post #2 of 7 Old 05-05-2013, 08:59 PM
Hillbilly61
Sounds like that the insulation on one (or more) of your spark plug wires has failed. Try replacing them. You saying that this only happens when the engine is running is very telling here. In (now) old vehicles with crude speakers and tuned to AM radio, it would be real telling there. The change of the pitch of the buzz would actually vary depending upon how hard you had the engine revved if the insulation crack was bad.
So, try swapping out the plug wires (make sure the replacements are of the insulated variety).
Hillbilly61 is offline
post #3 of 7 Old 05-05-2013, 09:09 PM Thread Starter
cbass68
Thanks Hillbilly! I'll get some insulated wires tomorrow and try that.
1980 CJ-7 - sold
1997 TJ - sold
cbass68 is offline
post #4 of 7 Old 05-05-2013, 10:14 PM
Hillbilly61
I get a good feeling that is what is going on with your vehicle & sound system. You described your problem pretty well. Just make sure all of the wires are swapped out. That includes the wire to the distributor too. By what I meant by "insulated" (these wires are all insulated) is for radio. Almost standard these days, but you might want to clarify when buying.
I have had breaks in it, such as you described, in the that you could actually hear the buzz picked up from power lines when driving under them tuned in to AM radio. All of these power sources (engine spark system, power lines, etc) readily broadcast radio noise that your system can readily pick up & play back to you via radio.
For the 'what is worth' category since you have already done this, a poorly grounded sound system (either the unit itself or the speakers) will buzz regardless of whether you are playing radio or a CD. This is why you saying that it only happens when tuned into radio was very helpful towards giving some advice back. Also, non radio insulated speakers of any sort (could be your PC) will also intermittently report a "dot the dot, the dotta" sound back too from your cell nearby cell phone if using the frequency that ATT and other carriers that use (will not happen with Verizon and their brethren - they use a different frequency).
All of this is from the "have had to deal with this 'crap' department!"
post #5 of 7 Old 05-06-2013, 02:45 PM Thread Starter
cbass68
Cool. I bought some premium insulated Autolites today but, won't get a chance to install them until later in the week. I'll keep you posted. Again, thanks for the help!
1980 CJ-7 - sold
1997 TJ - sold
cbass68 is offline
post #6 of 7 Old 05-11-2013, 09:39 AM Thread Starter
cbass68
I installed the premium spark plug wires this morning. That did the trick! I noticed a little moisture had previously gotten on the coil connection so, I used a little steel wool on it. Maybe that helped too?
Thanks again Hillbilly!!
This forum is great!
1980 CJ-7 - sold
1997 TJ - sold
cbass68 is offline
post #7 of 7 Old 05-19-2013, 04:42 PM
Hillbilly61
Glad it took care of things!
Good thing that you noticed that moisture had gotten on the coil connection and took care of it too. Not that it probably probably mattered about the RF noise you were getting, but it might have caused your vehicle to quit starting (or suddenly stopping when going down the highway) Moisture related corrosion usually does not stop once started... why you never want to buy a vehicle that has been in a flood. Engine & mechanicals may be fine, but the electrical system will gradually go to hell by the induced corrosion. Once started, it is like a cancer, as it never stops spreading.
