Build my own "amp kit" - JeepForum.com
post #1 of 5 Old 07-26-2013, 01:00 AM Thread Starter
zRoxxah
So I finally got the ZJ running again and while she was out of commission my new amp came.
It's a cheap Boss RIOT 1100M, I bought it just to have some bass while I'm upgrading. Anyways I'm using it to drive 2 12" Sony Xplod Subs that are 1200W. The part number escapes me.
I realized I bought a mono channel to drive two subs...so on the fly, can I connect the (+) wires on each sub to the (+) on the amp and then do the same for the (-) ones?
Also I don't really want to spend 100 bucks on an amp kit since my car was already wired for subs; all I need is a 4awg to run from the battery and for the ground, the fuse inside "the bubble", and speaker wire to connect the subs to the amp. Is this something I can pick up at let's say RadioShack or do I have to bite the bullet and shell out some bucks for the amp kit.
Matte Black '96 ZJ 4.0
IRO 3.5" Benchmark Lift, Bilstein 5100's, 31x10.5x15 Westlake SL369 A/T's, Moog Super Trail Boss SS, KOR Rad Support, Chopped-up Front Bumper
zRoxxah is offline
post #2 of 5 Old 07-26-2013, 03:00 AM
Holder350
1995 XJ Cherokee
I would not.....connecting 2 speakers in parallel will effectively lower their ohm impedance.
Check your speakers coil values and use the formula
1/R total = 1/R1 + 1/R2
Check your total ohms against the amps rating.
As for the cable you can buy it by the foot at most electrical supply houses. I personally like using welding cable.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 5 Old 07-26-2013, 06:52 AM
bob6987
the Boss RIOT 1100M is rated for 2 ohms, if the subs are each single voice coils at 4ohms each (only one + and - per speaker), wiring them in parallel will be ok.
if you run them in serial they will be at 8 ohms, the amp will run cooler but wont put out as much power.
you dont need to buy a kit. you can piece together the parts for the amp install, http://www.sonicelectronix.com/ has good prices.
If you are running power I would go 2 or 0 gauge... dont want to run new power cable if you upgrade or add an amp
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #4 of 5 Old 07-26-2013, 01:19 PM Thread Starter
zRoxxah
Thanks! I will wire them in parallel. I will go with 2awg, also where can I pick up one of those fuses in the plastic case?
zRoxxah is offline
post #5 of 5 Old 07-26-2013, 10:29 PM
bob6987
any place that sells car audio will have one. i like the ones that take a ANL fuse type, i have this one in my f250 Xscorpion Anl1010p
2012 JKU
bob6987 is offline
